Missing symbols on Ubuntu 20 mono - side panel is missing symbols - Messaggi
The missing symbols
I tried to:
See if i have everything enabled in Extensions Manager (yes)
install all sorts of font packages (Libre Office Math shows everything)
reboot
search for missing files
walk backwards on full moon
reboot again
search if anyone else had same problems (could not find any)
etc.
what could cause the problem and how to fix it?
Ubuntu 20.04 LTS
Downloaded the SMathStudioDesktop.0_99_7030.Mono.tar.gz
I have installed mono-complete using these instructions: https://www.mono-project.com/download/stable/#download-lin
Only errors I got were:
Installing mono (in the installation phase "sudo apt update" ) gave this error:
Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://download.mono-project.com/repo/ubuntu stable-focal InRelease' doesn't support architecture 'i386'
"Could not set X locale modifiers" when launching SMath on terminal
fixed it with
rm -Rf ~/.config/.mono (https://github.com/mono/mono/issues/18238)
Both, before and after, the symbols were missing.
The "plugins" folder
mono --version
Mono JIT compiler version 6.6.0.161 (tarball Wed Feb 5 07:34:41 UTC 2020)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
TLS: __thread
SIGSEGV: altstack
Notifications: epoll
Architecture: amd64
Disabled: none
Misc: softdebug
Interpreter: yes
LLVM: supported, not enabled.
Suspend: hybrid
GC: sgen (concurrent by default)
I'm going back to use the Windows version on VirtualBox because that Linux version using Mono just does not work!
WroteI could not install that old version, because the site is not working, when you click any version, it downloads the last stable.
Are you saying you can't download/install SS 6179 ?
That's by design. You have to click on the "requested file version" tab on the top of the box.
Steps:
(Just use Docker)
I follow this tutorial: https://github.com/bkjaya2020/smathstudio-docker
As a Fedora 32 user, I just did:
1. sudo dnf install docker
2. systemctl start docker
3. sudo docker create -t -p 8008:8080 --name smath --privileged=true bkjaya1952/smathstudio-docker (it would take some minutes)
4. sudo docker start smath
5. in the browser, go to http://localhost:8008/
That's it =)
SMath will show there fully functional!
I solved problem with wine...
1. sudo apt-get install mono-complete
2. sudo apt-get install winetricks
3. winetricks dotnet45
4. copy smath installation from windows (whole directory) to linux (kubuntu)
5. wine /home/user_1/smath_99_7030_wine/SMathStudio_Desktop.exe
result - all symbols in side panel.
obviusly since its running through wine performance is not as good as the mono version (Some lag is happening in my fairly old machine) so it would be fine to try to find a workaround in the mono version
I followed your instructions for using winetricks and just ignored all the error messages while the Windows .net dotnet45 was being installed.
Copied SMath from my Windows 10 machine and everything is now working again in LM20. All the symbols are displaying properly.
- the version available is 6.8, not 6.10 per the https://www.mono-project.com/
Does this solve anything for others? A set of instructions for us GUI people would be appreciated if this fixes things
PS:
- I uninstalled mono-complete from the machine
- I ran the commands in a terminal box from https://www.mono-project.com/download/stable/#download-lin
- My system said that it needed to be updated and one of the components said "mono 6.12.0.101" (no screenshot)
- still have the graphics issue
PPS:
I shut down the machine last night and turned it on this morning. There was an update for Mono, 6.12.101. I let it install (not sure if it's complete. I still have the graphical issue. Then re-ran
Citazionesudo apt install mono-devel
Thinking out loud ... Could it be a font issue?
[UPDATE]
Not a font issue. I copied my windows 10 fonts directory into my home directory home/{USR}/.local/share/fonts... unless I did that wrong
Below I listed what happened to sidebar step by step on Linux Mono builds.
Sorry for the big picture but I had to prtscr that so everything can be seen in one screen.
1- It was build 5905 when everything was fine.
2- When new functions added to matrices sidebar on build 5918, they didn't show up. But they are clickable.
3- Last working version beside new matrices functions was build 6437.
4- Starting from build 6470, a lot of sidebar buttons are missing. But sidebar button fonts are big on these builds.
5- Last big font but missing buttoned sidebar build was 6671.
6- On and after build 6839, buttons had slim fonts. This build had same amount of non-missing items as previous build and all alphabet items are shown.
7- The last full greek alphabet version was build 6995.
8- After build 7005, two alphabet buttons are missing too. These two additional they are not presented on previous builds.
You can not use them on SMath canvas either. They give only rectangle on regions not characters.
Wrote1- It was build 5905 when everything was fine.
I think this is a key! Look at the vector multiplication icon: it is visible on 5905 and not visible on 5918. I have checked what was changed between these two revisions and found one related change only! I have changed an icon a bit, from File non trovato. to File non trovato.. Other icons is visible (instead of new vectorize button added in the same revision).
So it seems like I've started to use another tool to create images for the toolbars, but I do not remember any details now.
Here is an archive with both images directly from the sources: linux_image_button.7z (689 B) scaricato 857 volta(e)., so maybe someone will find what is wrong in vectorumno-2477.gif against to vectorumno-321.gif (number here is a revision into repository). If we will understand it I will fix all the icons accordingly.
BTW: Today I am using PNG icon (
) instead of GIF, but we still have the issue on Linux... Actually all icons became invisible on 6470 because I've converted them to PNG format.Best regards.
WroteBTW: Today I am using PNG icon (
Peraphs if it's not something codec-related might be the size of the container wrt the size of the image (just an idea).
About these two images in particular seems they have different BG/transparent colors (white the old, black the new) and different color maps.
![2020-10-14 14_27_05-[vectorumno-2477] (importata)-1.0 (Colore indicizzato interi a 8 bit gamma, GIMP.png](/it-IT/files/Download/XxNsuR/2020-10-14-14_27_05-[vectorumno-2477]-(importata)-1.0-(Colore-indicizzato-interi-a-8-bit-gamma,-GIMP.png)
![2020-10-14 14_26_45-[vectorumno-321] (importata)-4.0 (Colore indicizzato interi a 8 bit gamma, GIMP .png](/it-IT/files/Download/kvhhyG/2020-10-14-14_26_45-[vectorumno-321]-(importata)-4.0-(Colore-indicizzato-interi-a-8-bit-gamma,-GIMP-.png)
But how this could be? Why it is shown correctly on Windows then?
WroteAbout these two images in particular seems they have different BG/transparent colors (white the old, black the new) and different color maps.
Please, could you check PNG image as well? Does it have the same colors?
WroteWhy it is shown correctly on Windows then?
Because it's Windows
Davide beat me to my first inclination, the transparency feature available in PNG format. (Example). However, I run the portable version on Windows and copied the files to Linux, so it's the same folders/folder structure
Question, on Linux, am I suppose to double click on "SMathStudio_Desktop.exe" or "smathstudio_desktop_mono" {no extension}. My version of "smathstudio_desktop_mono" is dated 05/30/2013. The following is what's in that file
exec mono "./SMathStudio_Desktop.exe" "$@"
WrotePlease, could you check PNG image as well? Does it have the same colors?
the PNG file has 2 colors (black and transparent black), however PNG format has alpha channel while GIF has just transparency. Transparency on black color might be the problem in mono?
![2020-10-14 15_37_01-[vectorumno] (importata)-1.0 (Colore indicizzato interi a 8 bit gamma, GIMP buil.png](/it-IT/files/Download/x6pS4P/2020-10-14-15_37_01-[vectorumno]-(importata)-1.0-(Colore-indicizzato-interi-a-8-bit-gamma,-GIMP-buil.png)
we can try if these works better (32bit and 32bit deinterlaced made with paint.net)
