Making Vector Elements Cumulative - Adding Vector Elements down the column - Messaggi
In the attachment at the start of Page.5 I (so far) am unable to construct a loop or something that cumulatively adds vector elements down the column. So I am manually doing this for now, any ideas?
I have started additions from the 6th element because first x4 were zero ...but I think you get the idea!
https://imgur.com/7KSBDM8
Secondly in the last page there is a 2D-graph. One can easily read the intersection of two lines however is there any solution to find the intercept of two lines when they aren't functions but are rather data points?
Remembraning.sm (38,42 KiB) scaricato 1154 volta(e).
no no ...I think I was unable to make you understand. The summation gives one value ...instead I wanted to have a cumulative elements in a vector. The latter thus can be plotted. please revisit the screenshot
Sum the vectors and vectorize ...
Maths Vectorize.sm (9,06 KiB) scaricato 1191 volta(e).
Thank you PompelmoTell
WroteJean Giraud, why do you add Line in the following code, I mean why not just type them separately or am I missing something?
Yes my friend, you are missing best using Smath feature,
1. the line | collects/instructs the project
2. the { collects for plotting
Visit attached Project PR EOS.sm
Here is your plot and cumulative.
Project PR EOS.sm (129,66 KiB) scaricato 1173 volta(e).
Thanks Jean. I myself am a chemical engineer & Equations of state example is very much appreciated!
mkraska, thanks for helping, but your file is created with a newer version of SMATh & throws error in my current version 0.98.6528
Wrotemkraska, thanks for helping, but your file is created with a newer version of SMATh
You are right: Martin latest version throws error in my 6179.
I love Martin code ... Bingo !
The code I provided should work, as it did previous Smath 5346.
I tested 3 programs to find the cumulative totals of a large array of 20820 elements.
The method of Sergio was incredibly fast, while other two methods were much slower.
Thanks Sergio.
Forgot to attach DATA file
Rainfal_Data.xlsx (486,31 KiB) scaricato 791 volta(e).
Cumulative Sum of a Large Matrix.sm (30,38 KiB) scaricato 1166 volta(e).
frapuano 09/08/2019 03:43:00
Hi Nugegodage. Try this other one.
Cumulative Sum of a Large Matrix.sm (25,32 KiB) scaricato 1435 volta(e).
(Notice that mi computer is very slow)
