"Structural Beam Analysis" plugin error
"Structural Beam Analysis" plugin error - Index outside matrix boundaries error - Messaggi
#1 Pubblicato: 16/01/2020 10:58:36
e.artola
e.artola
0 apprezzamenti in 4 post.
Hi everybody,
I'm trying to use the Structural Beam Analysis plugin, but I've got some problems.
When I open the “Beam Analysis” example I've got the next problem.
The error says "Indice fuera de los limites de la matriz" (Index outside matrix boundaries)
Could somebody help me with that?
Thanks in advance
#2 Pubblicato: 16/01/2020 15:38:24
Will be easier to doctor from the document, isn't it ?
#3 Pubblicato: 17/01/2020 04:46:25
e.artola
e.artola
I've got the problema with the example that's why I didn't send the file before.
You can find it attached.
Thanks
Beam Analysis Input Guide.sm (86,78 KiB) scaricato 1774 volta(e).
#4 Pubblicato: 17/01/2020 12:14:18
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Do an AppVersion on the file
There has been a lot of work under the engine by the developers since this was issued. You'll need to update it and preferably, repost. I don't do a lot of beam calcs, so I have not touched this in a while.
NOTE: Opened fine in 7251
#5 Pubblicato: 17/01/2020 13:56:19
127 apprezzamenti in 342 post.
I have the same problems as Eneko, with 7251 versions of SM
#6 Pubblicato: 17/01/2020 15:56:49
e.artola
e.artola
I've tryed in different ways to fix it but I continue with the same error.
#7 Pubblicato: 17/01/2020 23:57:33
CBG
CBG
78 apprezzamenti in 312 post.
works perfectly on SS7251
Carlos
#8 Pubblicato: 18/01/2020 00:01:12
NDTM Amarasekera
NDTM Amarasekera
130 apprezzamenti in 352 post.
There has been a lot of work under the engine by the developers since this was issued.You'll need to update it and preferably, repost.I don't do a lot of beam calcs, so I have not touched this in a while.
The original file showed Red while opening, but finally opened successfully in SS 7251.
Then saved as with a new name, which opens later without any such hassle.
#9 Pubblicato: 21/01/2020 08:12:13
e.artola
e.artola
Could somebody show me how to solve it please?
Thank you in advance
#10 Pubblicato: 21/01/2020 11:48:48
NDTM Amarasekera
NDTM Amarasekera
The renamed file is attached, including the PDF. I did not do any changes.
Hope you will be able to open it. Also update relevant plug-ins.
Cheers!.
Beam Analysis Input Guide_TEST.sm (387,42 KiB) scaricato 1675 volta(e).
Beam Analysis Input Guide_TEST.pdf (486,47 KiB) scaricato 1562 volta(e).
#11 Pubblicato: 21/01/2020 12:09:10
I confirm the problem highlighted by Eneko also on my pc with win7 Pro and SM SM "0.99.7251.32800".
The only dependency reported in the guide is the plugin "Structural Beam Analysis
Utility Functions by Redem Legaspi Jr." that is set up and active.
#12 Pubblicato: 21/01/2020 12:13:54
NDTM Amarasekera
NDTM Amarasekera
Mine is Win 10 Home Edition. SS version same as yours.
Cheers!
#13 Pubblicato: 21/01/2020 12:43:03
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Page Beam Analysis Utility Functions exists but I see this plugin for the first time. If anybody find sources I can update them to work state.
Citazione
Analysis of Beam with any number of supports and with any type of loadings.
The worksheet requires that the associated Plugin (Structural Beam Analysis Utililty Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath Studio Extension Manager tool.
The worksheet does the following:
1.) Plots Beam Diagram, Shear Diagram, Moment Diagram, Deflection
2.) Calculates Support Reactions
3.) Calculates Shear, Moment, and Deflection at any given point.
Refer to 'Beam Analysis Input Guide.sm' on how to use the plugin.
redemlegaspi1968@gmail.com
sergio 21/01/2020 12:55:00, NDTM Amarasekera 21/01/2020 14:53:00
#14 Pubblicato: 21/01/2020 13:21:13
Zigor Marroquín Martínez
0 apprezzamenti in 7 post.
Same problem as Eneko and PompelmoTell :___(
Thanks fro helping ndtma and uni!
#15 Pubblicato: 27/01/2020 07:52:07
Hi uni and thank you very much for offering your help.. I'm going to try to find the sources you asked for, mailing Redem Legaspi. Any specific file or extension?
Hugs!
Zigor
#16 Pubblicato: 27/01/2020 08:49:15
Gruppo: Moderator
Redem Legaspi can ask Anrey how to upload sources to svn. After that we'll can maintain his project without author.
As far as I can see, the last update was made by Andrey. Maybe he has sources.
#17 Pubblicato: 27/01/2020 11:14:01
You're right, uni..
I've already contacted Redem and he suggested me also writing Andrey; Redem can't recover right now plugin sources.
I've mailed Andrey. I'll keep you informed.
Thanks a lot for helping!
Zigor
#18 Pubblicato: 29/01/2020 12:12:55
eswte
eswte
0 apprezzamenti in 8 post.
Hi I have the same problem with the Beam Analysis, have you got some answer?
#19 Pubblicato: 05/02/2020 04:11:36
Gruppo: Super Administrator
Hello.
Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them.
Several days ago I've got permissions to fix an issue.
Plug-in functionality restored now. Tested ok with all available sample worksheets.
New version of a plug-in available using Extensions Manager.
Вячеслав Мезенцев 05/02/2020 05:17:00, sergio 05/02/2020 05:33:00, Martin_B 05/02/2020 07:10:00
#20 Pubblicato: 05/02/2020 06:35:03
Dear Andrey,
I've just download the plugin and check the SMath sheet.
I've only performed few tests, but it's working perfectly.
Thank you so much for your help and effort. Really.
Best regards!
Zigor
