How do I integrate Symbolically?
How do I integrate Symbolically? - Messaggi
#1 Pubblicato: 10/05/2018 20:23:24
Ryu945
Ryu945
0 apprezzamenti in 5 post.
How do I integrate symbolically?
#2 Pubblicato: 10/05/2018 21:54:23
How do I integrate symbolically ?
Generally, like this.
Davide Carpi 12/05/2018 03:23:00
#3 Pubblicato: 10/05/2018 22:35:04
... more procedures.
Integrate_000000 [ Source Code Maple].sm (9,66 KiB) scaricato 1364 volta(e).
#4 Pubblicato: 11/05/2018 00:03:19
Ryu945
Ryu945
For reference, I just installed SMath. I installed maple. Where is the integrate sign located in the program?
#5 Pubblicato: 11/05/2018 00:15:35
Wolfram Alpha integrator:
http://integrals.wolfram.com/index.jsp?expr=1%2F%28x%5E2%2B1%29&random=false
#6 Pubblicato: 11/05/2018 02:24:05
Ryu945
Ryu945
What are you trying to say?
#7 Pubblicato: 11/05/2018 08:17:25
1. Visit Wolfram Alpha for ultimate accuracy definite integral
2. Reproduce my first reply for indefinite integral .
3. Open the two attachments
4. Click on Smath menu to get the palette of stuff.
#8 Pubblicato: 11/05/2018 08:22:03
http://www.wolframalpha.com/input/?i=integrate+x%5E(0.5-1)*exp(-x)+from+0+to+0.1
#9 Pubblicato: 11/05/2018 08:37:42
#10 Pubblicato: 11/05/2018 08:41:26
From the last reply:
1. click on the image, copy
2. paste in Smath
3. DIY [Do It Yourself]
#11 Pubblicato: 11/05/2018 09:32:38
Arie
Arie
94 apprezzamenti in 285 post.
Hi Ryu
Welcome to the forums. Jean's first post outlined a how to create the indefinite integral, although it might not have been clear.
For example, to create the integral for x^2, you can type "int(x^2,x)" without quotes.
I do not believe there is a toolbar button for the indefinite integral.
-alyles
#12 Pubblicato: 11/05/2018 10:44:39
There was no palette indefinite integral in Smath 5346,
but from recollection, there was from f(x) menu.
Not reinstalled in 6179 ...
#13 Pubblicato: 11/05/2018 11:04:21
Ryu945
Ryu945
Thankyou. int( x^2,x) was what I was looking for (and I see now what that first picture was suppose to be /headdesk). I tried the example mentioned above with maple installed but I don't see the answer like I saw above. I see this instead.
#14 Pubblicato: 11/05/2018 11:49:59
Arie
Arie
Try right click and change optimization to symbolic.
Also you can use symbolic evaluation by hitting Ctrl + . (That is Ctrl and period) instead of =
#15 Pubblicato: 11/05/2018 12:13:30
Copy the image, paste in blank work sheet ... try to do it yourself.
Try hard !!! rescue yourself by downloading the work sheet.
It should work in your latest Smath version.
Integrate Wisely [Arc Maple].sm (8,54 KiB) scaricato 1087 volta(e).
#16 Pubblicato: 11/05/2018 12:43:56
... be productive to integrate, try it.
#17 Pubblicato: 11/05/2018 13:44:31
... this attached example is of prime importance.
It shows by how much the Simpson integrator can be OFF track !
Not even the first decimal is true !
Integrate Wisely [Arc Lagrange].sm (44,76 KiB) scaricato 1083 volta(e).
#18 Pubblicato: 11/05/2018 14:26:13
Ryu945
Ryu945
Thankyou for all of your assistance.
#19 Pubblicato: 11/05/2018 14:40:36
Ruben Sidranski
Ruben Sidranski
17 apprezzamenti in 465 post.
Jean,
Your overloading Ryu945. This appears to be his first experience with this type of software. Slow down and teach/explain. Notice the way alyles responded.
Welcome to the forum Ryu945. Play with the software, look at the Wiki, search the forums. When in doubt, ask. Don't be surprised if someone responds to a link from several years back ... thus, search the forum first.
as you progress and have specific questions, please post/attach your sheet like Jean did. This will allow others to help without having to redo or guess your work. Also, there is one function that I recommend you add to all of your sheets, appversion(). In particular, appversion(3) and appversion(-3). This tells us what version you are currently working in and what version the sheet was last saved in. Not common, but over the years, some updates have broken older sheets.
#20 Pubblicato: 13/05/2018 11:35:29
Gruppo: Moderator
You can use the free computer algebra system (CAS) Maxima from within SMath Studio.
See the Maxima forum topic. There is also a pre-configured portable SMath-Distribution, see link in my signature.
The german Handbuch has a lot of material on using the Maxima interface. Besides doing symbolic math it also gives many examples on how to use Maxima based graphics functions.
Davide Carpi 13/05/2018 13:09:00, frapuano 16/05/2018 12:23:00
