SMath Studio 0.98.6325 (26 April 2017) - Messaggi
Offre numerose funzionalità di calcolo e un'interfaccia utente ricca, tradotta in circa 40 lingue diverse. L'applicazione include inoltre un prontuario matematico integrato.
L'applicazione può essere facilmente estesa in base alle proprie esigenze. Lo strumento integrato "Gestione estensioni" consente di accedere a centinaia di risorse, sia ufficiali che di terze parti, tra cui: esempi d'uso, plug-in, applicazioni basate su SMath Viewer, frammenti di codice, traduzioni dell'interfaccia, libri interattivi, manuali e tutorial.
Download
SMathStudioDesktop.0_98_6325.Mono.tar.gz (1,24 MiB) scaricato 2769 volta(e).
SMathStudioDesktop.0_98_6325.Setup.msi (2,11 MiB) scaricato 5619 volta(e).
WroteBuilt-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet;
Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards)
WroteDue to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
I guess you have to remove image region plugin.
It is not really essential to have that feature but the response indicates successful execution, which is wrong.
Clear.sm (29,29 KiB) scaricato 1766 volta(e).
![2017-04-29 14_01_35-SMath Studio 0.98.6325 - [Clear.sm].png](/it-IT/files/Download/Yc7NkA/2017-04-29-14_01_35-SMath-Studio-0.98.6325---[Clear.sm].png)
Clear(,)=1 looks a Matlab code that clears the work space
from previous assigned values. Thus, it renders the algorithm
of the "work space" scalar wrt their respective scalar running
iterators x, y ...
In the attached "Fourier Quantum"... x,y are returned scalar
only for the double integrator. The Mathcad double integrator
is coded implicit of 'x,y' scalar ... much simpler but less
educative.
Fourier Quantum CoC Copy.sm (97,81 KiB) scaricato 1801 volta(e).
