SMath Studio 0.98.6325 (26 April 2017) - Сообщения
Скачать
SMathStudioDesktop.0_98_6325.Mono.tar.gz (1,24 МиБ) скачан 2756 раз(а).
SMathStudioDesktop.0_98_6325.Setup.msi (2,11 МиБ) скачан 5614 раз(а).
WroteBuilt-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet;
Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards)
WroteDue to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
I guess you have to remove image region plugin.
It is not really essential to have that feature but the response indicates successful execution, which is wrong.
Clear.sm (29,29 КиБ) скачан 1762 раз(а).
![2017-04-29 14_01_35-SMath Studio 0.98.6325 - [Clear.sm].png](/ru-RU/files/Download/Yc7NkA/2017-04-29-14_01_35-SMath-Studio-0.98.6325---[Clear.sm].png)
Clear(,)=1 looks a Matlab code that clears the work space
from previous assigned values. Thus, it renders the algorithm
of the "work space" scalar wrt their respective scalar running
iterators x, y ...
In the attached "Fourier Quantum"... x,y are returned scalar
only for the double integrator. The Mathcad double integrator
is coded implicit of 'x,y' scalar ... much simpler but less
educative.
Fourier Quantum CoC Copy.sm (97,81 КиБ) скачан 1795 раз(а).
