DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Messaggi
Simple test 2.
DotNumerics.ode.test2.sm (21,23 KiB) scaricato 1766 volta(e).
DotNumerics.ode.test2.pdf (79,99 KiB) scaricato 878 volta(e).
WroteSimple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24,51 KiB) scaricato 1862 volta(e).
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23,66 KiB) scaricato 1916 volta(e).
Updated for SS 0.99.6824. Intervals issue fixed.
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
Changes:
Updated.
dn.ode.kinetic1.sm (8,26 KiB) scaricato 2015 volta(e).
dn.ode.kinetic2.sm (12,59 KiB) scaricato 1883 volta(e).
dn.ode.kinetic3.sm (12,28 KiB) scaricato 1957 volta(e).
dn.ode.test1.sm (19,58 KiB) scaricato 1958 volta(e).
dn.ode.test2.sm (18,88 KiB) scaricato 1939 volta(e).
dn.ode.Amplitude detector.sm (20,17 KiB) scaricato 1988 volta(e).
dn.ode.kinetic1.pdf (77,42 KiB) scaricato 1109 volta(e).
dn.ode.kinetic2.pdf (93,05 KiB) scaricato 1035 volta(e).
dn.ode.kinetic3.pdf (91,31 KiB) scaricato 1028 volta(e).
dn.ode.test1.pdf (115,72 KiB) scaricato 1012 volta(e).
dn.ode.test2.pdf (120,44 KiB) scaricato 994 volta(e).
dn.ode.Amplitude detector.pdf (148,87 KiB) scaricato 1048 volta(e).
4 utenti hanno apprezzato questo post
NDTM Amarasekera 24/12/2018 09:44:00, sergio 24/12/2018 11:04:00, frapuano 24/12/2018 14:23:00, Radovan Omorjan 24/12/2018 14:52:00
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8,42 KiB) scaricato 1768 volta(e).
Вячеслав Мезенцев 22/08/2022 03:11:00
