1 pagine (14 elementi)
Offset surface creation - Messaggi
An initial surface is given, given by the "createmesh" function, which forms a
network with nodes.
Dyou want to create an offset surface, offset by an amount h from the initial.
The direction of displacement surface epends on the sign of h.
Sequence of calculation:
1.Restoring the normal from the nodal points of the initial surface and we get
the nodal points of the displaced surface.
2.We connect the resulting node points
The image is built on three-dimensional graphics and can be rotated with the mouse
network with nodes.
4 utenti hanno apprezzato questo post
Andrey Ivashov 19/10/2021 13:48:00, Oscar Campo 20/10/2021 18:42:00, Davide Carpi 20/10/2021 08:27:00, Alvaro 10/10/2021 20:58:00
Hi,Rezorex.I put the icon with the link using the "hyperlink" insert.
Here is a link to an article from Mapleprimes
https://www.mapleprimes.com/posts/211000-Preparing-A-Parametrized-Surface-For
Hi. Thanis Ber. A slightly different version, using only parametric functions.
Offset surface creation.sm (73,49 KiB) scaricato 1545 volta(e).
Offset surface creation.pdf (917,17 KiB) scaricato 1038 volta(e).
Thanks Alvaro, I continue to learn from you.
Fridel.
Fridel.
Converting Surfaces to Solids
The solid is formed from the initial surface, the offset surface, and the
lateral surface that connects them. The lateral surface is formed by normals
reconstructed from the boundary nodal points of the initial surface.
Solid.sm (36,96 KiB) scaricato 1550 volta(e).
Solid.pdf (309,58 KiB) scaricato 917 volta(e).
.png)
.png)
Alvaro 20/10/2021 23:56:00
Thanks ► Fridel, Alvaro
I don't have the courage to convert SS 6179 ... OK.
Keep up ... Jean.
Rotate 3D TREASURY_2 Parametric Explorer.sm (33,72 KiB) scaricato 1527 volta(e).
Keep up ... Jean.
WroteConverting Surfaces to Solids
Hi Fridel. Thanks, great job. In the attached an alternate mesh. Its advantage is that it consists of a single coordinate matrix, so it can be manipulated more easily, with translations, rotations and deformations. As disadvantages, it does not look so good and there may sometimes be a wrong line, but I guess only one.
pSolid_alternate_mesh.sm (51,99 KiB) scaricato 1475 volta(e).
pSolid_alternate_mesh.pdf (391,97 KiB) scaricato 856 volta(e).
Fridel Selitsky 21/10/2021 05:07:00
Normal to the surface on Rezonar's triangular mesh
NorSurAlvaro.sm (49,33 KiB) scaricato 1583 volta(e).
NorSurAlvaro.pdf (623,77 KiB) scaricato 911 volta(e).
.png)
.png)
Alvaro 24/10/2021 23:40:00
By same token, did you manage constructing Delaunay ?
We had no chance in Mathcad. Cheers ... Jean.
Hi. The same but with a different version for the triangular mesh.
NorSurAlvaro v2.sm (77 KiB) scaricato 1488 volta(e).
Creating surface thickness with triangular meshes
thickness.sm (56,02 KiB) scaricato 1585 volta(e).
thickness.pdf (732,98 KiB) scaricato 945 volta(e).
.png)
.png)
.png)
