Mathcad Toolbox - Contains analogs of functions from Mathcad - Messaggi
Thank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching.
CitazioneThank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching.
This is not the book itself, but the calculations that are used there. Unfortunately, the level of knowledge of the program leaves much to be desired. I made comments to the authors.
Hi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
3body.sm (37,44 KiB) scaricato 1712 volta(e).
WroteHi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
It is necessary to choose the conditions of the problem in such a way that the massive body intercepts the satellite.
WroteCitazioneThank you for the link, the book is really interesting and perhaps worth translating to German. At least I will use it for teaching.
So we can look forward for an inproved version. Could you please share your comments, eventually in PM...
The pdf can be found here. I downloaded all the stuff from the companion site, who knows how long we can access this.
Unfortunately, copying from the pdf to chatgpt for translation doesn't work
WroteUnfortunately, copying from the pdf to chatgpt for translation doesn't work
You can find one of the authors here. He is open to suggestions and comments.
Links:
1. Mathcad vs SMath
WroteWroteHi. Very interesting. It could be animated and add z axis. Maybe speed vectors too and the "ecliptic" plane.
Hi. Ok.
3body.sm (37,78 KiB) scaricato 1691 volta(e).
WroteHi. Ok.
A very witty, funny and clean solution.
7-13-Three-Planets 5 (Mathcad Block).sm (26,36 KiB) scaricato 2172 volta(e).
7-13-Three-Planets 5 (Mathcad Block).pdf (61,72 KiB) scaricato 1180 volta(e).
7-13-Three-Planets 6 (Mathcad Block).sm (26,11 KiB) scaricato 2184 volta(e).
7-13-Three-Planets 6 (Mathcad Block).pdf (67,28 KiB) scaricato 1037 volta(e).
WroteI Can't Install the Mathcad Toolbox Plugin
Does it happen only with this plugin or with others the same? Try deleting the plugins folder completely and try installing again.
WroteUtility for call dsolvers for initial and boundary values problems from a solver block.
You can add your documents as add-ons and then include them with the include() function.
This function automatically searches for files in the folder with extensions. This way you can update them individually.
File non trovato. File non trovato.
WroteWroteUtility for call dsolvers for initial and boundary values problems from a solver block.
You can add your documents as add-ons and then include them with the include() function. ... This function automatically searches for files in the folder with extensions. This way you can update them individually.
Hi. That function looks great. Is there an example of using a document as an add-on?
Wrote'Given' keyword also can be supported but I don't know how it will look like. Only the component has the ability to receive a set of elements on a sheet. The solution should be convenient and universal.
I think that SMath do not need a Given - Find block, because it have your solve block. For example, it could be used like this
WroteHi. That function looks great. Is there an example of using a document as an add-on?
Try to log in here using the registration data in the program: https://en.smath.com/upload/extensions.aspx
You should see this picture:
Next, you need to choose the type of extension
Before uploading a file, you need to fill in the document properties. Later, you can delete the file if necessary.
If the registration data is not suitable, then you need to request them from Andrey via e-mail.
The registered files will be available through the gallery.
It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this?
BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension?
Mathcad block.sm (13,77 KiB) scaricato 1735 volta(e).
