Mathcad Toolbox
Mathcad Toolbox - Contains analogs of functions from Mathcad - Messaggi
#101 Pubblicato: 30/11/2021 02:35:46
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Linear interpolation and linear spline interpolation are different things. I will try to find the formulas that are used in these functions.
We can restore the interpolation functions: lspline(), pspline() and cspline(). This is how the cspline() function works. Based on the attached document and file from the PTC Mathcad forum.
Click to enlarge Click to enlarge
Cubic spline interpolation using Mathcad (2009).pdf (256,71 KiB) scaricato 2762 volta(e).
cspline1.mcdx.zip (12,34 KiB) scaricato 535 volta(e).
cspline.sm (38,12 KiB) scaricato 1714 volta(e).
cspline.pdf (88,45 KiB) scaricato 918 volta(e).
#102 Pubblicato: 30/11/2021 09:58:24
With enough points, simply cinterp Smath.
ODE HIRES.sm (67,25 KiB) scaricato 1737 volta(e).
#103 Pubblicato: 04/12/2021 00:46:37
Gruppo: Moderator
rkfixed(3|4) added, but I still don’t know which derivative symbol is better to take. (ʹ) - modifier letter prime (U+02B9) used below. I don't know how to enter it from the keyboard.
Alvaro 04/12/2021 02:44:00
#104 Pubblicato: 04/12/2021 05:19:00
Gruppo: Moderator
Full set: interp(), [l,p,c]spline().
Click to enlarge
Odesolve interpolation test.sm (59,06 KiB) scaricato 1719 volta(e).
Odesolve interpolation test.pdf (102,91 KiB) scaricato 1078 volta(e).
(*) rkfixed() with a bug now, so you will see something differ.
#105 Pubblicato: 05/12/2021 06:55:49
Gruppo: Moderator
(ʹ) - modifier letter prime (U 02B9) used below. I don't know how to enter it from the keyboard.
This can be done in 2 steps:
1. Copy \02B9\ to text region. This code will turn into a text simbol (ʹ).
2. Select and copy it as variable name.
PS. It looks like it's time to combine all Mathcad functions into one plugin - Mathcad Toolbox. It will contain all such functions: ODE solvers, spline functions, in/out functions and so on.
Alvaro 05/12/2021 13:06:00
#106 Pubblicato: 05/12/2021 13:18:42
Hi. Your develop looks brillant.
2. Select and copy it as variable name. ...
Also, you can get any unicode char with this
... PS. It looks like it's time to combine all Mathcad functions into one plugin - Mathcad Toolbox. It will contain all such functions: ODE solvers, spline functions, in/out functions and so on.
And don't forget the possibility that the area simply returns the equations of the differential equation or a non-linear system of equations so that the user can then try to solve the ode or nle systems with the functions he chooses.
#107 Pubblicato: 05/12/2021 18:30:56
Gruppo: Moderator
This looks very interesting. Seems that it is not yet in the online gallery?
In principle, the built-in diff(1) operator would be an option but it looks ugly if applied twice.
The ordinary prime would be ok for me (just as it is used as tag in unit names), it is input as Shift # on german keyboards.
diff2.sm (2,79 KiB) scaricato 1702 volta(e).
#108 Pubblicato: 05/12/2021 22:15:07
I still don’t know which derivative symbol is better to take. (ʹ) - modifier letter prime (U 02B9) used below. I don't know how to enter it from the keyboard.
My preference goes for book style.
US keyboard D apostrophe (x):=
#109 Pubblicato: 06/12/2021 00:07:58
Gruppo: Moderator
I can't contact Andrey directly. The server does not allow compiling the sources, as there is no free space. Therefore, the latest changes are not yet available.
I've made some changes. I liked the idea with the str2num() function. Also I can override the diff(1) function, but that can be confusing.
Now it is possible to numerically solve the Cauchy problem for one variable: diff(y(x),x,n)=F(x,y(x),...,diff(y(x),x,n-1)) . Later, I will expand the rest of the ODE solvers to support this simplified form. But for this I need to combine plugins and add interpolation functions similar to Mathcad (lspline(), interp(), ...). It will be more convenient for me to test the solvers, comparing the results with Mathcad.
Block region collects equations in the form of a system and substitutes it as the first parameter into the function.
Click to enlarge
#110 Pubblicato: 06/12/2021 04:32:09
Gruppo: Moderator
I can add the ability to set this symbol directly in the document. This way you can change the default symbol.
sergio 06/12/2021 07:09:00
#111 Pubblicato: 06/12/2021 09:11:48
Gruppo: Moderator
SMath Studio compatibility
Plugin updated. Please try.
Examples:
Mathcad Block.sm Mathcad Block. Examples.sm
Changes:
- rkfixed() now works correctly;
- Odesolve block renamed to Mathcad Block;
- the task for the ODE solver in the usual mathematical notation is supported;
- default diff symbol is apostrophe ( ' );
- linterp() is used as an interpolation function;
- refactored.
Alvaro 06/12/2021 11:41:00, sergio 06/12/2021 10:52:00
#112 Pubblicato: 06/12/2021 13:41:05
Hi Viacheslav, thanks, great job. One question: Why to use linterp instead cspline? The problem with cspline is about the border of the interval, where you have only diff by the left and the right, and there you can adapt the cubic splines to be linear or parabolic, but in the interior of the interval I guess that it's better cubic splines interpolation.
ODEQuestion.sm (15,16 KiB) scaricato 1741 volta(e).
#113 Pubblicato: 06/12/2021 15:44:46
Gruppo: Moderator
I will add the interpolation functions ( interp(), lspline(),... ) to the plugin and rename it to Mathcad Toolbox. After that, it will be possible to test its work, comparing it with the Mathcad numerically.
Alvaro 06/12/2021 17:55:00
#114 Pubblicato: 07/12/2021 05:56:03
Gruppo: Moderator
Plugin updated.
Changes:
- plugin renamed to Mathcad Toolbox;
- version changed to 0.3.*;
- interp(), lspline() functions added;
- lspline() function used in any ode solvers.
File non trovato. File non trovato.
overlord 07/12/2021 09:10:00, Martin Kraska 07/12/2021 07:12:00
#115 Pubblicato: 07/12/2021 08:32:19
Gruppo: Moderator
Really nice generic block concept! It is a really good reason for updating the handbook and the portable distribution.
This is how to use it with symbolic solutions using Solve() (Maxima plugin):
Solve block.sm (5,37 KiB) scaricato 1746 volta(e).
Looking forward to a RK integrator for multi-DOF systems. This is how I would imagine the user interface.
Federpendel-block.sm (48,39 KiB) scaricato 1733 volta(e).
#116 Pubblicato: 07/12/2021 09:32:51
Gruppo: Moderator
This is the next step, but the existing solution is not stable and has some bugs.
#117 Pubblicato: 07/12/2021 11:13:30
Gruppo: Moderator
Plugin updated.
Changes:
- plugin merged with Mathcad File Access (all functions are inside Mathcad Toolbox);
- the condition has changed in the definition of the solver function (to support both directions of integration): (x-xmin)*(xmax-x)>=0;
- pspline() function added.
Arie 07/12/2021 11:35:00
#118 Pubblicato: 07/12/2021 14:00:34
Hi. In the meantime, we can play with things like this:
Solve block.sm (54,97 KiB) scaricato 1809 volta(e).
#119 Pubblicato: 08/12/2021 02:24:11
Gruppo: Moderator
Looks great, but something is missing.
Click to enlarge
Alvaro 08/12/2021 06:53:00
#120 Pubblicato: 10/12/2021 05:59:47
Gruppo: Moderator
Plugin updated.
Changes:
- fixed algorithm for selecting regions (Mathcad Block).
sergio 10/12/2021 08:25:00
