Newbie problem - Using a range of angles inside a cosine function
Newbie problem - Using a range of angles inside a cosine function - Trying to use cos(variable angle) - Messaggi
#1 Pubblicato: 03/10/2012 06:41:00
jjuddgb
jjuddgb
0 apprezzamenti in 2 post.
I'm trying to convert some old Mathcad files into SMath but am stuck with what must be an elementary problem, I've looked at various tutorials but can't find a solution, no doubt due to my own incompetence.
I am defining the following variables: angle:=72 and varangle:= 0, angle/2..360
In Mathcad if I then define: test(varangle):= cos(varangle) the output of test(varangle) displays correctly in a column.
If I try the same in SMath I receive either an 'argument must be scalar' or 'fill in all empty elements' error.
Thanks for any advice.
Screenshots of Mathcad and SMath attached.
btw, great software.
Mathcad - output.pdf (26,44 KiB) scaricato 998 volta(e).
#2 Pubblicato: 03/10/2012 07:49:27
kilele
kilele
134 apprezzamenti in 397 post.
Correct me if i'm wrong, trigonometric functions don't support arrays currently.
For now, you can do something like this.
cosinOfArray.sm (5,04 KiB) scaricato 1882 volta(e).
1752 28/09/2024 14:44:00
#3 Pubblicato: 03/10/2012 11:09:17
jjuddgb
jjuddgb
Thank you kilele
#4 Pubblicato: 03/10/2012 11:31:19
Fridel Selitsky
Fridel Selitsky
520 apprezzamenti in 451 post.
You can convert the vector into a system (by w3b5urf3r_reloaded)
Regards, Ber7
https://smath.com/wiki/GetFile.aspx?File=cosinOfArray%5b1%5d.rar
Davide Carpi 03/10/2012 13:33:00
#5 Pubblicato: 03/10/2012 11:33:28
Fridel Selitsky
Fridel Selitsky
Regards, Ber7
#6 Pubblicato: 28/09/2024 14:44:50
1752
1752
0 apprezzamenti in 3 post.
did arrays appear in trigonometric functions?
#7 Pubblicato: 28/09/2024 16:09:41
127 apprezzamenti in 342 post.
now you can use the "vectorize" function, which you also find in the side panel, and perform the trigonometric function element by element.
1752 28/09/2024 16:30:00
#8 Pubblicato: 29/09/2024 22:22:50
Gruppo: Moderator
An alternative to the vectorize() function is the use of index vectors.
They, however, only work if they are used in a definition.
Worksheet1.sm (5,28 KiB) scaricato 1644 volta(e).
sergio 29/09/2024 23:37:00
