RF Resistance Calculation
RF Resistance Calculation - Using ber, bei functions - Messaggi
#1 Pubblicato: 29/11/2017 17:47:22
Norm Schutzkus
Norm Schutzkus
9 apprezzamenti in 90 post.
My first post. I'm trying SMath instead of MathCad P4.File non trovato.File non trovato.
Having difficulties transferring the RF resistance sheet from MC15. The ber, bei functions are missing. I added plugin EFI for Mathcad for the "Jv" (vs. Jn) function but it doesn't appear in the listing of available functions.
Attached is the mc file and my attempt to transfer to SMath.
I welcome the collabs help to move forward.
Sincerely,
nasch
#2 Pubblicato: 29/11/2017 19:05:03
Check if you can do something from the Smath built-in
mwbessl [i,j,k,y] from the f(x) menu.
#3 Pubblicato: 29/11/2017 22:23:52
Norm Schutzkus
Norm Schutzkus
Thanks, for your reply. Unfortunately, I do not see "mwbessl..." listed. Maybe something that I need to activate? Is there a certain plugin I need to load?
Thanks, again
#4 Pubblicato: 30/11/2017 13:23:56
You may have to install from the plugin list.
Click on "Tools", click "Plugins" ... install all.
Otherwise, rescue to "Smath Doctors" ... [Martin, Davide ...]
Bessel Midwest.sm (8,83 KiB) scaricato 1102 volta(e).
#5 Pubblicato: 30/11/2017 14:32:40
Norm Schutzkus
Norm Schutzkus
Thanks, again. Unfortunately, the "mwbessel..." function are not defined. I have 23 plugins loaded, all with green check-marks so I think they are all working. "Install all" is not there.
Then again, I do not have admin rights (my work PC), so that may be a problem?
#6 Pubblicato: 30/11/2017 15:02:34
Sorry Collab, can't help + ... hope Smath Doctors catch your pain.
#7 Pubblicato: 30/11/2017 15:27:18
Gruppo: Moderator
Try with my portable distribution, see signature. There, the mathlib.dll (mathcad special functions) is installed and the bitness of the executable is adjusted.
The screenshot below is from the interactive handbook. You find it using the [?] button in the toolbar in the distribution mentioned above.
Goto Plugins> EFI for SMath Studio> Special functions.
2017-11-30 19_23_19-SMath Studio 0.98.6484 - [Section Special functions.sm].png
#8 Pubblicato: 30/11/2017 16:04:14
1.558 apprezzamenti in 1.868 post.
Gruppo: Moderator
Try this.
Links:
1. Cephes Mathematical Library.
Citazione
mathlib.dll must be uninstalled (removed manually) from the Mathcad EFI plugin. Cephes Mathematical Library contains same functions.
#9 Pubblicato: 30/11/2017 16:17:14
Gruppo: Moderator
No, you have to set 32-bit version flag for the SMath Studio Desktop exe file.
Links:
1. Matlab C++ Math Library 2.1 (Win32)
#10 Pubblicato: 30/11/2017 17:22:09
Norm Schutzkus
Norm Schutzkus
Many thanks! "Jv" is now defined. But "arctg" is not. Another plugin?
#11 Pubblicato: 30/11/2017 17:52:58
Gruppo: Moderator
Name of trigonometric functions depend on the function naming type in global settings of your smath studio; in your case you should look for atan
#12 Pubblicato: 30/11/2017 18:11:27
Norm Schutzkus
Norm Schutzkus
Thank you! Now it computes, but the value; Rac(100kHz) is negative. Should be 141.553Ohm/Mi. I need the "angle" function definition from Mathcad. angle(x, y) Returns the angle from the x-axis to a line containing the origin and the point (x,y). Results are in radians between 0 and 2π, excluding 2π.
#13 Pubblicato: 30/11/2017 18:24:09
angle(x, y)
NFG ... arg(1+1*i)=45°
#14 Pubblicato: 30/11/2017 18:39:13
Norm Schutzkus
Norm Schutzkus
Using an old MC definition I obtained a better value:
#15 Pubblicato: 01/12/2017 11:40:01
These two documents may be of interest next blue moon.
Mostly if you need accurate Γ(x) ... Smath built-in ± 4/5 D
Bessel JY.sm (64,79 KiB) scaricato 1139 volta(e).
Maths Special Gamma(x) 15D.sm (75,81 KiB) scaricato 1155 volta(e).
#16 Pubblicato: 01/12/2017 14:53:48
Norm Schutzkus
Norm Schutzkus
Many thanks!
#17 Pubblicato: 06/12/2017 18:17:45
Norm Schutzkus
Norm Schutzkus
Thanks again for the collab's help. The work sheet displays the same result as MC. AC-DC Resistance Using Bessel Functions.sm (12,68 KiB) scaricato 1209 volta(e).
Now I have a fault using a modified sheet that the "Result is above max. allowed positive number." Capture.JPG. The limit for Rac(f) is 9.3MHz, then the error shows.
The result should be 219 micro-ohm/cm. Why the limit?
nas
Bellow Equiv Resistance.sm (14,43 KiB) scaricato 1176 volta(e).
#18 Pubblicato: 07/12/2017 00:31:46
Here, it says ... Jv(,,) not defined.
#19 Pubblicato: 07/12/2017 01:26:28
I understand the skin effect from my > 50 years back Electronics.
What I don't understand is the so complicated route to Ohms/MHz.
If you could tabulate some values of that Oms/MHz, I will attempt
a model fit ... something like I did for ITER [Cadarache].
#20 Pubblicato: 07/12/2017 08:40:50
Gruppo: Moderator
Something triggered in the factorization of the ratio be(...)/be'(...) you can make it working with a trick
