how to improve calculation speed here?
how to improve calculation speed here? - Messaggi
#1 Pubblicato: 10/01/2022 07:27:12
Johannes Piel
Johannes Piel
2 apprezzamenti in 20 post.
Hi all,
I have two files here, one in smath, one in mathcad.
The mathcad file is calculated about 1000 times faster, does anyone have a tip how to speed up the .sm file?
File non trovato. File non trovato.
#2 Pubblicato: 10/01/2022 09:24:28
127 apprezzamenti in 342 post.
By setting the formulas with the numeric optimization option switches from 29s to 19s. Still away from your expectations
#3 Pubblicato: 10/01/2022 09:42:53
Johannes Piel
Johannes Piel
16 more equally good improvements and it is solved...
Thank you Sergio
#4 Pubblicato: 10/01/2022 11:37:19
OFF topic of the speed, I don't understand your histogram.
Histogram take raw data from collection, ultimately to get a PDF.
Stat Histogram DEMO.sm (23,33 KiB) scaricato 1294 volta(e).
Stat Histogram QUICK.sm (57,75 KiB) scaricato 1311 volta(e).
#5 Pubblicato: 14/01/2022 13:28:39
Johannes Piel
Johannes Piel
Hi Jean,
Sorry for the delay, unfortunately I found no time...
I have attached my histogram again, revised it a bit and commented it.
Actually I think it does exactly what it should, but I have to admit
that I don't know the exact definition of a histogram 8)
Histogram_JP.sm (18,82 KiB) scaricato 1334 volta(e).
And again about the speed: I played a little with my definition of "rnorm"
and come to the strange result that my vector is calculated fastest when
I calculate it in pieces of 20 elements.
I would be happy if a more experienced user could explain this to me.
speed.sm (17,28 KiB) scaricato 1334 volta(e).
Have a nice weekend!
Johannes
#6 Pubblicato: 14/01/2022 15:10:20
Arie
Arie
94 apprezzamenti in 285 post.
This is the function I use for sampling from normal distribution.
speed-lyles.sm (17,6 KiB) scaricato 1335 volta(e).
#7 Pubblicato: 28/01/2023 08:51:14
evsp
evsp
0 apprezzamenti in 3 post.
Hi All,
I am new here, and facing similar problems. I intend to replace MathCad to an alternative solution due to PTC's pricing and support policy. I was very happy to find SMATH, and I started to test it. For short calculations it's a good alternative, but it seems very-very slow when long iterations are needed. I made a short loop both in Mcad and Smath containing just a few multiplications, and calculating it 1000000 times took ~0.2s for Mcad14, ~1s for Mcad8, and 32s for SMATH. So now I am a bit upset...
#8 Pubblicato: 28/01/2023 10:11:27
Arie
Arie
Care to share your .sm file?
Sometimes the are improvements to be made in how algorithms are structured.
#9 Pubblicato: 28/01/2023 10:46:03
In some instances, Smath is slightly faster than Mathcad 11.
However, almost not observable.
In other instances, Smath is horribly slow.
1 min Julia in Mathcad takes over 2 hrs in Smath
Same observation Fourier CoC ... and more.
Please, attach your document for Smath Community to doctor.
#10 Pubblicato: 28/01/2023 11:09:26
Your document does not open 'incorrect format'
Visit Wikipedia for Histogram.
#11 Pubblicato: 28/01/2023 11:50:23
Gruppo: Moderator
SMath may not be fastest among them.
But some tricks can be applied.
It may improve calc speed slightly.
#12 Pubblicato: 28/01/2023 14:28:57
evsp
evsp
speedtest.sm (4,53 KiB) scaricato 1319 volta(e).
This is the file I made exclusively for speed check. There is no need to improve this calc by modifying it's structure, it is just for test purposes not a real task.
I started to use Mathcad in the last century (V6.0). I made several calculations for example to simulate transient temperature rise of electrical rotating machines. I know there are better tools but I am familiar with MathCad that's why I am looking for a similar sw.
#13 Pubblicato: 28/01/2023 16:06:16
#14 Pubblicato: 28/01/2023 16:44:01
Attach your experimental data set.
#15 Pubblicato: 28/01/2023 20:03:55
Gruppo: Moderator
And speed of your test code fails under SMath drastically.
But we all know these issues. For huge iterations SMath is not useful.
Anyone who plans to use this software should know this, SMath is a one-man show.
There are no paid programmers who can give all their time to SMath.
Only a handful of developers are included in writing and enhancing the code.
And they are doing this in their spare time, without any charge.
Maybe Andrey improve iteration speeds in future, who knows.
We can request something, it is up to Andrey include or improve that.
It is what it is, a free software which gives us mathcad interface.
Reagrds
#16 Pubblicato: 29/01/2023 08:28:17
evsp
evsp
"Anyone who plans to use this software should know this"
Yes, sure. I installed SMath 3 days ago, and now I am checking it's usability for my tasks.
And many respect to Andrey! In the last few days I also found many points where SMath is superior to MathCad.
#17 Pubblicato: 29/01/2023 09:52:11
Arie
Arie
Just for demonstration purposes, I've been able to increase the speed of this calc ~25% on my machine just by using vectorization rather than the for loop. It's still not near the performance you'd like, but just goes to show there are often things to be done to improve calculation speed. Vectorization isn't always possible in some algorithms, but when it is, it's generally faster.
speedtest.pdf (35,36 KiB) scaricato 831 volta(e).
speedtest.sm (8,36 KiB) scaricato 1326 volta(e).
#18 Pubblicato: 29/01/2023 10:41:06
Maths algo DEMANDS.sm (5,85 KiB) scaricato 1288 volta(e).
#19 Pubblicato: 29/01/2023 15:24:04
In few days, imprudent to glorify the unknown yet.
#20 Pubblicato: 29/01/2023 18:36:37
Gruppo: Moderator
You can't be more correct.
SMath may be behind than MathCad speed-wise.
But in terms of usability, features, visual aspects SMath is way better.
Just plugin support is a huge plus single alone.
