how to apply a conditional to an interval
how to apply a conditional to an interval - Messaggi
#1 Pubblicato: 05/01/2022 18:03:42
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1 apprezzamenti in 27 post.
Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y
TESTE TENSAO ADM MATRIZ.sm (5,41 KiB) scaricato 1235 volta(e).
#2 Pubblicato: 06/01/2022 01:50:51
Gruppo: Moderator
I didn't understand what to calculate in sigma function.
A little more explanation would help to resolve it.
TESTE TENSAO ADM MATRIZ_r1.sm (8,44 KiB) scaricato 1258 volta(e).
Mostra spoiler
#3 Pubblicato: 06/01/2022 07:57:04
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
I don't understand the problem, only to get a plot.
Good morning,
I reworded the file with an SPT matrix, my goal is to loop to find the value of sigma h in the depth that I inform in the input I am attaching a photo of what the final result should look like with the graph
TESTE TENSAO ADM MATRIZ.sm (13,15 KiB) scaricato 1246 volta(e).
#4 Pubblicato: 06/01/2022 15:04:40
Hi. I think that this could be the solution.
TESTE TENSAO ADM MATRIZ.sm (5,88 KiB) scaricato 1243 volta(e).
#5 Pubblicato: 06/01/2022 16:49:36
Gruppo: Moderator
I still don't understand purpose of for() loops. (not in your solution, original question)
Removing for()'s and calculating directly won't change the result.
#6 Pubblicato: 06/01/2022 19:06:33
Hi overlord. I guess because using γ.s2(h)*h isn't correct, there the correct acumulation is γ.s2(h)*Δh
TESTE TENSAO ADM MATRIZ.sm (10,8 KiB) scaricato 1215 volta(e).
#7 Pubblicato: 07/01/2022 08:51:39
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
Good morning,
thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
see the resolution of the problem in the attached image
#8 Pubblicato: 07/01/2022 11:23:15
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
At this point, up to You to handle the project.
I understood nothing in that big image.
TESTE TENSAO ADM MATRIZ (in_situ parametric).sm (18,6 KiB) scaricato 1287 volta(e).
PERFECT FELL LIKE A GLOVE is there a way to rotate the result of the graph 90 degrees?
#9 Pubblicato: 07/01/2022 16:01:35
...some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Hi. You can try to change the input values by yourself.
#10 Pubblicato: 07/01/2022 17:44:30
This is a way to do that in SMath.
TESTE TENSAO ADM MATRIZ v2.sm (455,7 KiB) scaricato 1352 volta(e).
#11 Pubblicato: 08/01/2022 11:14:01
... updated from Alvaro latest addition.
Cleaned image(s) for publishing the traced reference.
You can have as many sets of parameters [p,d] as you wish,
even of different length as long as you update respectively.
Project Algo_Parameters.sm (661,95 KiB) scaricato 1263 volta(e).
I guess the last 4 'x' points [18,19,20,21] should be removed.
#12 Pubblicato: 08/01/2022 14:36:52
Gruppo: Moderator
Razonar's post has answer already. Jean's post is a re-post.
No reason to re-post same file with some enigmatic, non-related, preceded functions.
TESTE TENSAO ADM MATRIZ v2.sm (455,7 KiB) scaricato 1352 volta(e). <--- Razonar's post
Project Algo_Parameters.sm (661,95 KiB) scaricato 1263 volta(e). <--- Jean's shameless repost (don't download this)
#13 Pubblicato: 08/01/2022 16:45:12
Offered as demanded in two separate parts in same document.
Thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Project Algo_Parameters Copy.sm (663,42 KiB) scaricato 1264 volta(e).
#14 Pubblicato: 08/01/2022 18:28:58
Gruppo: Moderator
I am pretty sure topic owner didn't request from someone to re-post one anothers sample.
Alvaro 08/01/2022 20:58:00, fedeghi 09/01/2022 07:57:00
