1 pagine (8 elementi)
x,y time depended graphs - Messaggi
WroteIs it possible to draw such a graph.
Yes it is possible.
Here is your request.
Graphs_1.sm (4,68 KiB) scaricato 1325 volta(e).
You can get the 3D graph with the Maxima plugin
Scatter plot_Kr(adattato).sm (161,33 KiB) scaricato 1350 volta(e).
inspired by the discussion on this forum
full discussion
full discussion
Hi. Just another way, in addition to the solutions offered by Overlord and Pompelmo, using the ability of XYPlot plugin for plot parametric curves, as is explained here.
XYPlot Parametric.sm (5,61 KiB) scaricato 1284 volta(e).
... export your creation
Utilities XY plot [Butterfly].sm (29,82 KiB) scaricato 1165 volta(e).
Wroteusing the ability of XYPlot plugin for plot parametric curves
Parametric ability is a good addition.
I wish 2D-Plot has this feature too.
I also would like animation for XY-Plot.
The Maxima plugin provides plotting functions, among them parametric plots. For details look for "kraska smath handbuch".
Note that there seems to be a png export glitch. The region t:=25 is disabled in the sheet but not grayed out in the export (image below). The parameter variable obviously must be undefined, otherwise the x and y expressions are just numbers.
para.sm (137,85 KiB) scaricato 1347 volta(e).
I have no recollection of Parametric Engineering project(s).
Whatever, this document advances your Parametric Journey.
Ultimately, export the project as a standard data table for publishing.
... offered up to the derivatives of the piece-wise project.
Comments, more help ... Welcome.
Utilities XY plot Parametric.sm (89,13 KiB) scaricato 1303 volta(e).
