x,y time depended graphs
x,y time depended graphs - Messaggi
#1 Pubblicato: 17/10/2022 13:58:40
D D
D D
0 apprezzamenti in 8 post.
I was looking for a similar topic on the forum, but I couldn't find it.
Is it possible to draw such a graph.
Graphs.sm (4,42 KiB) scaricato 1403 volta(e).
#2 Pubblicato: 17/10/2022 16:16:22
Gruppo: Moderator
Yes it is possible.
Here is your request.
Graphs_1.sm (4,68 KiB) scaricato 1324 volta(e).
sergio 17/10/2022 16:38:00, Oscar Campo 18/10/2022 07:13:00
#3 Pubblicato: 17/10/2022 16:33:54
127 apprezzamenti in 342 post.
You can get the 3D graph with the Maxima plugin
Scatter plot_Kr(adattato).sm (161,33 KiB) scaricato 1349 volta(e).
inspired by the discussion on this forum
full discussion
#4 Pubblicato: 18/10/2022 02:53:01
Hi. Just another way, in addition to the solutions offered by Overlord and Pompelmo, using the ability of XYPlot plugin for plot parametric curves, as is explained here.
XYPlot Parametric.sm (5,61 KiB) scaricato 1283 volta(e).
#5 Pubblicato: 18/10/2022 10:08:54
... export your creation
Utilities XY plot [Butterfly].sm (29,82 KiB) scaricato 1164 volta(e).
#6 Pubblicato: 18/10/2022 18:43:50
Gruppo: Moderator
Parametric ability is a good addition.
I wish 2D-Plot has this feature too.
I also would like animation for XY-Plot.
#7 Pubblicato: 19/10/2022 05:17:14
Gruppo: Moderator
The Maxima plugin provides plotting functions, among them parametric plots. For details look for "kraska smath handbuch".
Note that there seems to be a png export glitch. The region t:=25 is disabled in the sheet but not grayed out in the export (image below). The parameter variable obviously must be undefined, otherwise the x and y expressions are just numbers.
para.sm (137,85 KiB) scaricato 1346 volta(e).
#8 Pubblicato: 20/10/2022 10:00:35
I have no recollection of Parametric Engineering project(s).
Whatever, this document advances your Parametric Journey.
Ultimately, export the project as a standard data table for publishing.
... offered up to the derivatives of the piece-wise project.
Comments, more help ... Welcome.
Utilities XY plot Parametric.sm (89,13 KiB) scaricato 1302 volta(e).
