Syntax for linterp
Syntax for linterp - What is the correct syntax for linterp(x,y,z) - Mensajes
#1 Publicado: 14/2/2019 18:57:41
RegCurry
RegCurry
0 me gusta en 57 mensajes.
Sorry to be so slow on Smath. Some thing work like Mathcad and some don't. I need help with the correct syntax for the interpolation function linterp. I have tired all combinations of syntax that I can think of and none work in the attached Smath file.
Help would be appreciated.
RMD CALCULATION.sm (15,13 KiB) descargado 1292 vez(es).
#2 Publicado: 14/2/2019 19:17:53
RegCurry
RegCurry
Oops I meant this way to no success.
RMD CALCULATION.sm (15,27 KiB) descargado 1254 vez(es).
#3 Publicado: 14/2/2019 20:30:15
Arie
Arie
94 me gusta en 285 mensajes.
I don't think vectorize works with this function. It is expecting a single value in argument 3. Checkout my linterp2 function in the attached. I think it does what you want.
RMD CALCULATION.sm (18,24 KiB) descargado 1262 vez(es).
Note: In my program, it is not necessary to initialize the result. However, I have found that in cases of large vectors, it speeds up processing time to initialize a vector to the expected size and then fill in values. I generally just do this as standard practice now even if it's not necessary.
#4 Publicado: 14/2/2019 20:47:17
RegCurry
RegCurry
Thanks much. You are a real help.
I did not realize that the interpolation functions required additional programming. I incorrectly assumed it was like Mathcad. Many things are like Mathcad, but clearly not all.
Thanks again.
Reg
#5 Publicado: 14/2/2019 20:56:20
Arie
Arie
No problem!. Welcome to the forum. There are a lot of people here who are regular contributors and will help you with questions you have. For me, it's why I primarily use SMath for my calculations.
Regarding similarity/dissimilarity to MathCAD... once you start using SMath more you'll stop thinking in "MathCAD" and be able to think in "SMath". As a former MathCAD convert myself, I really started to come into my own when I stopped thinking of how I would do things in MathCAD and started figuring out how best to use SMath.
#6 Publicado: 14/2/2019 21:16:12
Some thing work like Mathcad and some don't.I need help with the correct syntax for the interpolation function linterp.
Read carefully: linterp, cinterp are 1/1 Mathcad
Smath ainterp has special virtues not found in Mathcad.
Smath linterp, cinterp, ainterp are 1/1 Mathcad as interpolation.
but are 0/1 as scalar functions. In many instances, it is possible
to recast the problem in the form of infinitesimal analysis.
I found no way to render a_c_l interp scalar Mathcad style.
Though, I have the Mathcad code. Don't confuse yourself, a_c_l_interp
they plot on the canvas, i.e: they plot scalar.
scalar is a kernel internal vanishing iterator
Next question: please attach the Smath document.
#7 Publicado: 14/2/2019 21:53:35
Sorry, I downloaded the other one.
Either blue/red will each have an extraordinary good model fit,
for further processing [deriv, int].
#8 Publicado: 14/2/2019 22:57:58
RMD CALCULATION (J).sm (18,81 KiB) descargado 1274 vez(es).
#9 Publicado: 14/2/2019 23:51:13
... a bit .
RMD CALCULATION (J).sm (26,09 KiB) descargado 1279 vez(es).
#10 Publicado: 15/2/2019 0:08:02
... interesting stuff .
Interpolate [Linterp, Spline2D].sm (118,34 KiB) descargado 1109 vez(es).
#11 Publicado: 15/2/2019 0:20:02
RegCurry
RegCurry
Jean,
I appreciate your attempt at helping me. Unfortunately, I am new to Smath and don't really understand your syntax in your attached sm file. See my comments in the attached file.
RMD%20CALCULATION%20(J)-1.sm (21,15 KiB) descargado 1406 vez(es).
Sorry, I am just too new to this code to appreciate your input.
Thanks again,
Reg
#12 Publicado: 15/2/2019 0:41:09
Hi. You can do some plots too.
RMD CALCULATION.sm (10,79 KiB) descargado 1298 vez(es).
#13 Publicado: 15/2/2019 1:46:57
RegCurry
RegCurry
Thanks to all. I was able to find some useful stuff from everyone. Here is where I was headed.
RMD CALCULATION.sm (16,94 KiB) descargado 1214 vez(es).
#14 Publicado: 15/2/2019 1:57:46
Thanks again,
Reg
Hello Reg ... answered in blue
RMD CALCULATION (J in_blue)-1.sm (24,61 KiB) descargado 1230 vez(es).
#15 Publicado: 15/2/2019 3:51:44
Grupo: Moderator
Just a note.
Pay attention to the plot by Alvaro. He uses often neded lele() function (Custom functions plugin) for checking if the value is in a range: Xmin<=x<=Xmax
frapuano 15/2/2019 5:52:00
#16 Publicado: 15/2/2019 12:47:44
Thanks to all.I was able to find some useful stuff from everyone.
... more in there for publishing.
Little Smath doing so much, so nice !
RMD CALCULATION (J).sm (35,64 KiB) descargado 1266 vez(es).
#17 Publicado: 15/2/2019 18:55:22
RegCurry
RegCurry
Is this XY plot new? I find it really helpful.
RMD CALCULATION.sm (18,33 KiB) descargado 1220 vez(es).
#18 Publicado: 15/2/2019 22:48:25
Is this XY plot new?I find it really helpful.
Not new, just from applied Smath features as in older SS 6179.
