1 páginas (14 elementos)
Phasor - Mensajes
I need to draw phasors (lines-vectors) for AC circuit analysis.
- Line from origin to a point.
- Line from a point to another
The magnitude and the angle or Real and Imaginary parts are known.
Is there any related example?
Thank you,
Basile
Thank you,
Basile
Thank you Jean.
Any way to use different colour for some segments?
Put an arrow or a circle at the end?
Have a text to identify each segment?
Basile
Basile
You can use X-Y Plot Region for this.
XYPlot. Draw shapes.sm (19,85 KiB) descargado 3271 vez(es).
XYPlot. Draw shapes.pdf (92,91 KiB) descargado 2276 vez(es).
WroteThank you Jean.
Basile
Hello Basile,
You should be able to build your circuit with the attached.
Make something, attach and we will add text if you can't.
Circle_rkfixed Arrow.sm (27,63 KiB) descargado 1254 vez(es).
2D Util Bar Arrow Model.sm (22,97 KiB) descargado 1225 vez(es).
Circle_rkfixed Clock.sm (23,28 KiB) descargado 1268 vez(es).
Basile
Hello, Basile
On that one you can do a bit more.
Too much may be too much, isn't ?
Maths Polygon.sm (17,1 KiB) descargado 1267 vez(es).
Hello Jean and Uni,
Why the Lv is not defined?
I express the matrices as function.
And then the vectors evaluate!
What are the red squares to the right?
It looks that this approach of drawing vectors is a begging.
I shall work on it.
Thank you,
BasilePage2-error.sm (12,71 KiB) descargado 1369 vez(es).
I shall work on it.
Thank you,
WroteWhat are the red squares to the right?
Red square in the scroll bar points at the errors in the document.
More elegant arrows proposed.
Page2-error.sm (8,34 KiB) descargado 1420 vez(es).
NDTM Amarasekera 26/5/2019 5:25:00
Hi Jean,
The arrows fail when the length of the vector changes.
I have tried as a percentage of length but does not look nice.
Scaling the vectors to always be one but will loose real values
Any good idea?
Is there a way to auto-scale the 2D plot or X-Y plot?
One of the vectors is out of the visual plane.
Thanks,
Basile
Any good idea?
Thanks,
Basile
As I said before:
WroteHow about a simple arrow?
WroteI do not know how to do it better. The arrow should look good in different scales and in its own size.
WroteAny good idea?
None of the quick plot or X_Y plot can be made X, Y directions scalable
similar to Mathcad 11 ... to me: useless.
From an original X_Y plot creation, stretch by handles respect aspect ratio.
If you modify the X, Y directions [max/min], apply close enough HL, HW ratio.
Page2-error (1).sm (11,66 KiB) descargado 1432 vez(es).
NDTM Amarasekera 24/5/2019 23:22:00, frapuano 25/5/2019 2:46:00, Вячеслав Мезенцев 25/5/2019 6:08:00
With both arrow heads, based on Jean's method.
Thank you Jean.
Both Arrows.sm (30,49 KiB) descargado 1211 vez(es).
Why I am getting errors when load your file?
The latest Stable: SMath Studio 0.99.7030 (01 April 2019)
Archivo no encontrado.Archivo no encontrado.
At the end I am able to open the file.
I do the same with two arrows 2π apart, but yours is more elegant.
Basile
Basile
