1 páginas (7 elementos)
Multiple Binary Boolean Operators in if statement - Add multiple binary Boolean "or" / "and" operators without force parenthesis - Mensajes
When I try to perform this if-or statement:
if a=1 ^ a=2 ^ a=3
x=4
else x =5
I end up with this due to forced parenthesis:
if ((a=1 ^ a=2) ^ a=3)
x=4
else x =5
Could we have capability for multiple binary operators without forced parenthesis enclosure?
if a=1 ^ a=2 ^ a=3
x=4
else x =5
x=4
else x =5
Hi. The short and honest answer is not. The long and tricky answer is that you can, but you must edit the .sm file and delete the lines with (
However, unless it's for some publishing purpose or something like that, I don't think it's convenient. Also, you can neither copy nor edit it without the parentheses reappearing.
and_tryck.sm (2,75 KiB) descargado 1602 vez(es).
WroteThink in term of productive Bolean.
... lot more involved. Adapted from Frank Rioux MCD 11.
Fourier Quantum 2C Mask.sm (22,51 KiB) descargado 1658 vez(es).
WroteYou can always create some function to make it look like you are working with some set of numbers
Tanks Davide ... coded/saved.
Take care ... Jean.
Maths Conditional Davide.sm (12,36 KiB) descargado 1644 vez(es).
sergio 9/5/2022 12:46:00
![2022-05-09 13_37_05-SMath Solver - [some all none.sm_].png](/es-ES/files/Download/zxmznX/2022-05-09-13_37_05-SMath-Solver---[some-all-none.sm_].png)
