EXCEL (2003+) I/O with recalculation and export to PNG
EXCEL (2003+) I/O with recalculation and export to PNG - Uses EXCEL PIA (2003+) to import/export data to and from XLS/XLSX files - Mensajes
#101 Publicado: 20/9/2021 14:18:08
Ricardo_Herrera
Ricardo_Herrera
1 me gusta en 8 mensajes.
Citar
XLSXupdate.txt (1,81 KiB) descargado 1356 vez(es).
first it is a great surprise is to be able to greet his person.
Thank you very much for your time. and by Smath Studio. Thank you very much for what you teach and what you do.
Rikardo21
#102 Publicado: 20/9/2021 16:14:43
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Please try to update the plugin. Your version is from last year and is out of date.
#103 Publicado: 20/9/2021 16:48:37
Ricardo_Herrera
Ricardo_Herrera
XLSXupdate.txt (1,85 KiB) descargado 1397 vez(es).
Update plugin, but error persists.
Keep holding
Rikardo21
#104 Publicado: 20/9/2021 19:19:45
Grupo: Moderator
This problem appears due to the presence of old keys in the registry, which will contain the wrong path to Excel. Try to search in Google for a solution to your problem using the error text from the log file:
Excel HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED)
#105 Publicado: 21/9/2021 11:29:09
João Felipe Seráfico Melo
7 me gusta en 62 mensajes.
Ricardo, I updated the plugin and made a Quick Repair in my Office 365, restarted the pc and now it works perfectly.
The issue is some bug in Office register.
Thank you for your compliments, Ricardo! Glad to see my videos are helping!
#106 Publicado: 21/9/2021 12:37:50
Ricardo_Herrera
Ricardo_Herrera
Thank you very much I have reinstalled office and now it works.
thanks for everyone's help.
A hug from a distance.
to all.
Rikardo21
João Felipe Seráfico Melo 21/9/2021 14:48:00
#107 Publicado: 1/11/2021 8:46:47
Hi! I'm having trouble sending String variables to Excel.
For instance, ". - / ! ? ;" turns into \002E\\0020\\002D\\0020\\002F\\0020\\0021\\0020\\003F\\0020\\003B\ in Excel.
I'm using most recent SMath and Excel I/O versions.
#108 Publicado: 1/11/2021 10:05:32
Ricardo_Herrera
Ricardo_Herrera
Hello, good morning, could I send a screenshot to see the error that generates a hug from a distance
Rikardo21
#109 Publicado: 10/11/2021 12:26:03
oscar mauricio
oscar mauricio
1 me gusta en 10 mensajes.
Hi, I have the same problem as Ricardo, any recommendations to solve it?
Mostrar spoiler
#110 Publicado: 11/11/2021 5:35:29
Grupo: Moderator
SMath Studio compatibility
Plugin updated.
Changes:
- excel_in(): text encode issue fixed.
João Felipe Seráfico Melo 11/11/2021 8:48:00, oscar mauricio 11/11/2021 8:49:00
#111 Publicado: 11/11/2021 8:57:18
oscar mauricio
oscar mauricio
Thank you very much, fixed with update
#112 Publicado: 3/7/2022 4:18:14
Grupo: Moderator
Plugin updated.
Changes:
- added support for environment variables;
- refactored.
Alvaro 3/7/2022 5:03:00
#113 Publicado: 3/7/2022 5:04:57
Plugin updated. ...
Hi Viacheslav. An example about what does that mean? Thanks.
#114 Publicado: 3/7/2022 6:10:06
Grupo: Moderator
You can use operating system environment variables in the file path.
A 4 usuarios les gustó este mensaje
NDTM Amarasekera 3/7/2022 8:00:00, churichuro 3/7/2022 12:59:00, Alvaro 3/7/2022 15:51:00, oscar mauricio 7/7/2022 11:37:00
#115 Publicado: 7/7/2022 11:54:58
oscar mauricio
oscar mauricio
Hello thanks for the plugin, I found a problem in the excel_In() command. I present it in the image, I hope it can be resolved in future versions.
#116 Publicado: 8/7/2022 4:45:19
Grupo: Moderator
Plugin updated. Please try.
Changes:
- ToCell(): Globals.Excel.DecimalSeparator replaced by the CultureInfo.GetCultureInfo( "en-EN" ).NumberFormat.NumberDecimalSeparator;
- ToCell(): Double.Parse() fixed;
- part of the book "Excel 2002 VBA Programmer's Reference" added (Chapter 22. International Issues).
Click to enlarge
oscar mauricio 8/7/2022 16:00:00
#117 Publicado: 8/7/2022 7:01:35
Grupo: Moderator
It is possible to simplify the interface. I can add a new feature. You can suggest your own version for a new feature.
#118 Publicado: 9/7/2022 6:43:56
Grupo: Moderator
In a future release I will remove functions from ExcelIOCom to XLSXupdate. One function and one operand will be added.
Archivo no encontrado. Archivo no encontrado.
churichuro 9/7/2022 11:09:00, sergio 9/7/2022 11:20:00
#119 Publicado: 9/7/2022 12:41:31
Grupo: Moderator
SMath Studio compatibility Examples
Changes:
- excel operand and excel() function added;
- readCell() and writeCell() moved from the ExcelIOCom plugin;
- examples added;
- refactored.
sergio 11/7/2022 5:47:00
#120 Publicado: 12/7/2022 3:40:45
Grupo: Moderator
There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable:
excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML"
Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as:
- create books, add and delete sheets;
- accessing named ranges;
I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable.
oscar mauricio 15/7/2022 21:52:00
