EXCEL (2003+) I/O with recalculation and export to PNG
EXCEL (2003+) I/O with recalculation and export to PNG - Uses EXCEL PIA (2003+) to import/export data to and from XLS/XLSX files - Mensajes
#121 Publicado: 14/11/2022 15:29:27
Alexander O. Melnik
Alexander O. Melnik
127 me gusta en 498 mensajes.
Grupo: Moderator
There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable:
excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML"
Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as:
- create books, add and delete sheets;
- accessing named ranges;
I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable.
Hello Uni,
It has been years since I have touched this plugin. Thank you for keeping it up to date and expanding its functionality! I use this plugin close to daily. I intend to add couple function calls to work with EXCEL Macro and perhaps a region to display the EXCEL range (so that Image Region plugin is not needed).
What do I need to know so that I do not interfere with useful changes you have made?
Cheers
Sasha
#122 Publicado: 16/11/2022 13:26:47
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
You can use Initialize() and GetTermsHandled() methods to add your features as before. If you add code and do not remove what is there, then there should be no problems. If problems arise, I will help to resolve them.
#123 Publicado: 14/10/2023 2:13:58
STEPHAN Boivin
STEPHAN Boivin
0 me gusta en 1 mensajes.
Reading only 0s using excel_OUT()
For those in Canada, My Windows 10 had a "," separator that prevented the plug-in to read the data in Excel.
The bug appeared when I decided to change the data format to numbers to have one decimal precision.
It was showing only 0s.
Changing the "," with a "." in the regional Windows setting was successful. Still showing "," in excel.
Great plugin
Thanks
#124 Publicado: 14/10/2023 2:28:28
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
Great plugin
Thanks
it's a known occurrence - I had difficulty incorporating regional settings into the plugin
#125 Publicado: 27/8/2025 14:51:26
susilo widyatmoko
susilo widyatmoko
5 me gusta en 9 mensajes.
the last time, my smath file still works. But now, the calculation cannot run. maybe the syntax is changed. image.png
sorry, it solved after login
Editado 28/8/2025 3:26:23
Oscar Campo 28/8/2025 9:59:34
