1 páginas (15 elementos)
Numerical parameterization implicit surfaces of the form f (x, y, z) = 0 - Mensajes
The grid lines are found by Draghilev Method
Method 1.
Building a line of intersection of the required surface
with the plane x = 0. This line is rotated in steps of 2 * Pi / s
about a vertical axis by an angle 2 * Pi, where s is the number of steps (the grid lines)
Method 1.
Davide Carpi 31/5/2015 7:19:00
The graph an implicit surface depicted by lines
Examples of the idea of the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/questions/219995-Finding-A-Convinient-Parametrization-Of-Surfaces#answer233804
Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.
Two surfaces are taken from the site
http://xrt.wikidot.com/gallery:implicit
The calculation algorithm:
1.Find the line of intersection of the given surface with the plane Z=0
2.Through each point hold the plane x1 = C and find the line of intersection of that plane with a given surface.These lines represent a given surface.
Davide Carpi 30/1/2017 9:18:00
Thanks for these two animations. In each one, the last three plots
stay red, though the animated plot works fine. A small detail:
each work sheet has three definitions left over at page 17.
Thank you Jean,
Worksheets corrected. In addition, in the algorithm for calculating along with x1 = C can be used x2 = C:
double torus x2.sm (73,26 KiB) descargado 1316 vez(es).
The tube in the form of a line of intersection of the cylinder and the torus (See post 7)
http://en.smath.info/forum/yaf_postst2307_Method-A-B--Draghilev-and-animation-spatial-mechanisms.aspx
Time calculation, 9 min.
Villarceau 9.sm (39,38 KiB) descargado 1297 vez(es).
Davide Carpi 1/2/2017 5:58:00
Helical Tube
NonCirc.sm (53,28 KiB) descargado 1284 vez(es).
TubeCir.sm (53,28 KiB) descargado 1339 vez(es).
Davide Carpi 1/3/2017 6:42:00
The surface of the Wikipedia
https://en.wikipedia.org/wiki/File:Tri-brezel.svg
WiciSurf.sm (106,91 KiB) descargado 1330 vez(es).
Non-circular cylindrical vessels with quasi-ellipsoidal ends
Krivoshapko S.N. Ivanov V.N,Encyclopedia of Analytical Surfaces ,Springer,2015
Non-circular cylindrical vessels.pdf (1,26 MiB) descargado 926 vez(es).
Non-circular cylindrical vessels.sm (209,71 KiB) descargado 1335 vez(es).
Shell1.sm (255,15 KiB) descargado 1372 vez(es).
Shell2.sm (33,38 KiB) descargado 1348 vez(es).
Shell3.sm (34,18 KiB) descargado 1300 vez(es).
Thanks Ber7 for the work sheets [Not finished downloading].
If you visit this document, I'm wondering:
"How to add red points in this plot".
Thanks in advance ... Jean
Maths sph2xyz.sm (13,82 KiB) descargado 1391 vez(es).
Hello Jean,
Unfortunately, the 3d chart does not allow you to draw points.
Exit (hopefully temporary) -make a 3d chart on a 2d chart.
Maths sph2xyz2d.sm (21,1 KiB) descargado 1329 vez(es).
Nice examples!
Just some remarks for those who want to play around with Maxima Draw.
ImplicitMaxima_Kr.sm (492,51 KiB) descargado 1399 vez(es).
![2018-02-06 08_55_49-SMath Studio - [ImplicitMaxima.sm_].png](/es-ES/files/Download/BoD4rH/2018-02-06-08_55_49-SMath-Studio---[ImplicitMaxima.sm_].png)
- Instead of Image region with Draw() command you can use Maxima Draw3D region with interactive zoom, rotation and resize and a settings dialog.
Insert-> Maxima-> Draw3D - The performance isn't overwhelming, as the image is recalculated for each interaction.
- The snippet "draw" provides help texts for the available draw commands and options.
- Follow the link in my signature to see how to configure SMath with Maxima.
A 4 usuarios les gustó este mensaje
Вячеслав Мезенцев 6/2/2018 6:15:00, Radovan Omorjan 6/2/2018 6:22:00, frapuano 6/2/2018 10:28:00, Fridel Selitsky 6/2/2018 5:08:00
