Enter data in a field that receives the calculated data
Enter data in a field that receives the calculated data - Mensajes
#1 Publicado: 29/10/2017 10:15:51
Krid
Krid
0 me gusta en 16 mensajes.
I use Smath Viewer - *.exe
How to make it possible to enter data in a field that receives the calculated data,
Explanation in the picture
#2 Publicado: 29/10/2017 13:17:16
Grupo: Moderator
Hello Kriss,
you can't as well as you can't enter data in results in the worksheet (or in result's cells in excel, f.e.); what are you trying to do exactly?
#3 Publicado: 29/10/2017 14:24:10
Krid
Krid
Hello Davide Carpi,
For example,
the data retrieved from the database or a calculation
and the User can change this value or accept the given value.
(In other words - the default value)
as a variable a, as shown in the picture above, because we initially set the value that the user can change it
#4 Publicado: 29/10/2017 15:04:46
Grupo: Moderator
I understand the point, as for now the only way is to change the logic of your script (f.e. creating a tab with database-driven inputs, another with user-driven inputs) or to use controls (checkbox, combobox...) to drive the behavior
#5 Publicado: 30/10/2017 12:01:50
Krid
Krid
Thank you, Davide Carpi!
Yes, I also thought about this solution.
If there are no other suggestions, I will use your proposed solution.
#6 Publicado: 10/11/2017 3:00:08
Krid
Krid
Thought about it and would like to offer few solutions to this problem.
The message to the respected Davide Carpi, the developer controls.
Numeric up-down - control
1. To add to - Canvas setting - Tag - value
2. In settings add a property to - Hide the sliders - (increase/decrease)
get visually similar to control - TextBox
ComboBoxList - control
1. In settings add a property - IsEditable
like in standard controls (WPF, WinForms)
- for manual input of values
With respect
