1 páginas (15 elementos)
Problems with x-y plots - Mensajes
I have just tried to use Smath, after a break of two or three months. I can't get the x-y Plots to work. When I try to adjust the scales, etc, from the defaults, I get the message "object does not match target type" in most/all sections.
I checked with an older file that used x-y Plots - the plots displayed properly, but I still got the same messages when I tried to access the scales, etc.
When I launched Smath yesterday I was offered a new, updated version - I accepted - was this a mistake, has something changed?
Any help would be gratefully accepted.
TIA
Jon
TIA
Jon
Very interesting. What operating system, SMath Studio version and X-Y Plot version?
Yes, there has been some updating, but no such side effects have been observed yet.
Thanks for your interest.
Windows 11 Home
Archivo no encontrado.Archivo no encontrado.
Is this what you mean?
Jon
Windows 11 Home
Jon
WroteIs this what you mean?
Yes.
The problem may be related to the fact that you don't have the required version of .Net Framework installed. Usually the current version is sufficient, but the component itself is developed using an older version (.Net Framework 2.0). Try checking or installing version .Net Framework 2.0 or 3.5 for Windows 11.
It's strange that the component worked on the same machine before. Others have no problem because they are most likely running older versions of operating systems or have the required versions of the .Net Framework.
No problems here as well.
XYplot.sm (9,88 KiB) descargado 1827 vez(es).
If you install the development tools plugin, in the "Insert" > "Development tools" > "System informations" dialog you can retrieve all the relevant framework and system information.
SMath Studio: SMath Studio Desktop 1.2.9018.0, 64-bit
OS: Microsoft Windows NT 10.0.22631.0; Windows 10 Pro, 64-bit
Screen: 1920x1080 px, 96x96 dpi, 96 GP.CDPI
Localization: language=ENG; dec.symbol=<period>; arg.separator=<semicolon>; OS dec.symbol=<comma>; OS arg.separator=<semicolon>; OS d.g.separator=<period>; units=eng;
Framework: CLR 4.0.30319.42000
installed versions:
v2.0.50727 2.0.50727.4927 SP2
v3.0 3.0.30729.4926 SP2
v3.5 3.5.30729.4926 SP1
v4
Client 4.8.09032
Full 4.8.09032
v4.0
Client 4.0.0.0
Plugins:
- [AppDir] AreaRegion - 1.11.9018.0
- [AppDir] HTMLFileType - 1.14.9018.0
- [AppDir] ImageFileType - 1.11.9018.0
- [AppDir] MathRegion - 1.11.9018.0
- [AppDir] PictureRegion - 1.10.9018.0
- [AppDir] PlotRegion - 1.11.9018.0
- [AppDir] SMathFileType - 1.11.9018.0
- [AppDir] SpecialFunctions - 1.12.9018.0
- [AppDir] StandardToolboxButtons - 1.1.9018.0
- [AppDir] TextRegion - 1.11.9018.0
- [AppDir] ViewerFileType - 1.1.9018.0
- [UserDir] 3D Plot Region (Chart3DLib) - 0.1.7806.5325
- [UserDir] ALGLIB® - numerical analysis library - 1.0.8025.20709
- [UserDir] Biquaternion - 0.1.8037.2733
- [UserDir] ButtonRegion - 0.1.0.0
- [UserDir] Cephes Mathematical Library - 1.0.8034.38340
- [UserDir] CheckBoxList Region - 1.0.7806.5399
- [UserDir] Combinations Function - 1.0.8986.24645
- [UserDir] ComboBoxList Region - 1.0.8763.41296
- [UserDir] Conditionally Formatted Label - 1.0.8138.35464
- [UserDir] CoolProp Wrapper - 6.4.8214.13502
- [UserDir] Custom Functions - 1.1.8726.29023
- [UserDir] Custom Glyphs - 1.1.7783.42782
- [UserDir] Data Exchange - 1.1.7813.24580
- [UserDir] Development Tools - 1.1.7490.41956
- [UserDir] DotNumerics - 1.1.8269.16536
- [UserDir] EXCEL (2003+) I/O with recalculation and PNG export - 2.1.8225.33551
- [UserDir] FFTPACK - 1.1.7563.3712
- [UserDir] Hyperlink Region - 1.0.7806.5225
- [UserDir] Image Region - 2.100.9040.19576
- [UserDir] Maple Tools - 1.1.8665.21209
- [UserDir] Mathcad File Access Functions - 1.0.8011.30679
- [UserDir] Mathcad Toolbox - 0.4.8520.34563
- [UserDir] MatrixExtensions - 1.0.8302.28555
- [UserDir] MaximaPlugin - 1.98.8797.27896
- [UserDir] NomoPlugin - 1.0.8302.30461
- [UserDir] Nonlinear Solvers - 1.1.7097.23301
- [UserDir] Numeric Up-Down Region - 1.0.8763.41162
- [UserDir] Pie Chart Region - 1.0.8770.25505
- [UserDir] PPTXplugin - 0.1.0.0
- [UserDir] RadioButtonList Region - 1.0.8763.40835
- [UserDir] Run - 0.2.7786.3193
- [UserDir] SectionsDB - 0.1.0.0
- [UserDir] SetOperations - 0.4.8992.40087
- [UserDir] Slider Region - 1.0.9012.24042
- [UserDir] Snapshot Region - 1.0.8770.19140
- [UserDir] Statistical Tools - 1.0.8868.19241
- [UserDir] Table Region - 0.3.8770.23606
- [UserDir] Text Region Utilities - 0.4.7802.40621
- [UserDir] WaterSteamPro - 0.8.8348.30162
- [UserDir] Writer Region - 0.23.8034.36139
- [UserDir] XlsxImportExport - 1.3.7845.24796
- [UserDir] XMCDFileType - 1.13.9019.2329
- [UserDir] X-Y Plot Region (JXCharts) - 0.3.9043.20036
- [UserDir] ZedGraph Region (ZedGraph) - 0.1.7806.5613
Thanks for your help, guys. This is starting to reach the bounds of my competence!
These are the details of my system.
SMath System Details.txt (1,7 KiB) descargado 1522 vez(es).
The XYplot.sm file works and displays fine, but I still get the "object does not match target type" message if I try to format the plot.
I'm a high-level, maths type of user, not a low-level/OS nerd, so I've never messed around with .Net Framework before (or even heard of it!). I'll have to find out what it's all about. Hopefully changing to an older version won't screw up anything else I'm using. Or, at least I can get back to where I am now.
Jon
Jon
I seem to have version 4.8.9032.0 of .Net
Jon
Jon
You're welcome. As for sure you miss any framework before 4.0
It should be enough to install the framework 3.5, you can found detailed instructions here.
The frameworks before/after 4.0 are different and run as parallel entities.
I've just downloaded .Net 3.5, using the instructions at
https://www.howtogeek.com/880208/how-to-enable-net-framework-2-0-and-3-5-in-windows-11/
which I found before I saw Davide's reply. They appear to be doing much the same thing.
Unfortunately, there is no change - I still cannot format the XY plot.
Any other suggestions, anyone?
Jon
Jon
WroteAny other suggestions, anyone?
You can install an older version from the list here:
https://smath.com/en-US/view/XYPlotRegion/history
1. Remove the current version of the plugin from the program.
2. Restart the program.
3. Drag the archive with the plugin to the program window with the mouse. This is an alternative installation method.
Thanks for this Uni.
Things have got a bit busy here lately - I'll try these in the next few days and get back to you.
Jon
Jon
I seem to have solved my problem. While looking to delete and try an older version of XYPlot, it occurred to me to uninstall & reinstall Smath. So I did, and it worked! Everything now seems to work as expected - so far. Maybe I should have thought of that before!
Thanks for your help, all.
Jon
Jon
Davide Carpi 10/11/2024 21:32:00
