1 páginas (12 elementos)
Spline Contour - Spline Contour - Mensajes
This one works well for the given data set. Mesh finer at will and if needed,
bilinear ... not much use for bilinear, whereas "spline" is just something.
Spline Esplina [AI2000].sm (23,66 KiB) descargado 1224 vez(es).
... a faster version: one twin col extractor removed.
By same token, I wonder why the col extractor col(,,) is so slow ?
Spline Esplina [AI2000].sm (23,75 KiB) descargado 1249 vez(es).
"By same token, I wonder why the col extractor col(,,) is so slow ?"
You can speed up calculation if o are using "eval":
Spline Esplina [AI2000] (1).sm (25,27 KiB) descargado 1232 vez(es).
Thanks Ber7 for "speedy Gonzalez". In fact, the "uN"
conditional code is redundant in this dataset.
Here is the latest version, even faster.
Spline Esplina [AI2000].sm (23,66 KiB) descargado 1269 vez(es).
Jean,calculation speed will be doubled, if we use the advice of Андрей
http://en.smath.info/forum/resource.ashx?a=14504&b=2
Spline Esplina [AI2000] 2.sm (20,98 KiB) descargado 1278 vez(es).
Davide Carpi 13/9/2016 11:45:00
Thanks Ber7,
... now she is a bomb [2 sec] !
Spline Esplina [AI2000].sm (22,82 KiB) descargado 1290 vez(es).
WroteYou forgot to specify first element of u vector.
By doing so you can speed up calculation even more:
Thanks Andrey, damned me !
While you are there, can you speed up "DeBoor" ?
Spline De Boor [Esplina].sm (47,76 KiB) descargado 1225 vez(es).
Done
Spline De Boor [Esplina]_mod.sm (47,37 KiB) descargado 1307 vez(es).
Timings:
Regards.
Timings:
- 6.1 seconds by 0.97.5890
- 2.3 seconds by 0.98.6096
Regards.
Thanks Andrey,
... for the local definition of Sx(v), Sy(v).
Must be consistant with all upward local definitions.
Quite right Andrey: 'u' is 'm', which 'm' is redundant.
I must have constructed N_(v,j) aroud 'u' from some source,
thus easier to check the coding. The attached work sheet
has been refactored with auxilliary explanations.
Can be used as model for DeBoor, pretty easy to adapt to
any project. Spline order is linear interpolation around
the polygon. Spline order 2 is "convex hull" per say.
They are about the only two types splines useful for
technical works [?]
Spline De Boor [Loop].sm (41,68 KiB) descargado 1280 vez(es).
technical works [?]
