Spline Contour
Spline Contour - Spline Contour - Сообщения
#1 Опубликовано: 12.09.2016 14:36:46
This one works well for the given data set. Mesh finer at will and if needed,
bilinear ... not much use for bilinear, whereas "spline" is just something.
Spline Esplina [AI2000].sm (23,66 КиБ) скачан 1189 раз(а).
#2 Опубликовано: 12.09.2016 19:08:01
... a faster version: one twin col extractor removed.
By same token, I wonder why the col extractor col(,,) is so slow ?
Spline Esplina [AI2000].sm (23,75 КиБ) скачан 1212 раз(а).
#3 Опубликовано: 12.09.2016 21:59:52
Fridel Selitsky
Fridel Selitsky
"By same token, I wonder why the col extractor col(,,) is so slow ?"
You can speed up calculation if o are using "eval":
Spline Esplina [AI2000] (1).sm (25,27 КиБ) скачан 1197 раз(а).
#4 Опубликовано: 12.09.2016 23:07:59
Thanks Ber7 for "speedy Gonzalez". In fact, the "uN"
conditional code is redundant in this dataset.
Here is the latest version, even faster.
Spline Esplina [AI2000].sm (23,66 КиБ) скачан 1235 раз(а).
#5 Опубликовано: 13.09.2016 03:08:10
Fridel Selitsky
Fridel Selitsky
Jean,calculation speed will be doubled, if we use the advice of Андрей
http://en.smath.info/forum/resource.ashx?a=14504&b=2
Spline Esplina [AI2000] 2.sm (20,98 КиБ) скачан 1238 раз(а).
Davide Carpi 13.09.2016 11:45:00
#6 Опубликовано: 13.09.2016 07:58:11
Thanks Ber7,
... now she is a bomb [2 sec] !
Spline Esplina [AI2000].sm (22,82 КиБ) скачан 1256 раз(а).
sergio 13.09.2016 08:17:00, NDTM Amarasekera 13.09.2016 11:14:00
#7 Опубликовано: 13.09.2016 11:23:31
2 343 сообщений из 4 046 понравились пользователям.
Группа: Super Administrator
You forgot to specify first element of u vector.
By doing so you can speed up calculation even more:
Regards.
Davide Carpi 13.09.2016 11:45:00, NDTM Amarasekera 13.09.2016 12:01:00
#8 Опубликовано: 13.09.2016 12:08:37
Thanks Andrey, damned me !
While you are there, can you speed up "DeBoor" ?
Spline De Boor [Esplina].sm (47,76 КиБ) скачан 1191 раз(а).
#9 Опубликовано: 13.09.2016 12:47:49
Done
Spline De Boor [Esplina]_mod.sm (47,37 КиБ) скачан 1272 раз(а).
Timings:
  • 6.1 seconds by 0.97.5890
  • 2.3 seconds by 0.98.6096
Regards.
#10 Опубликовано: 13.09.2016 15:32:56
Thanks Andrey,
... for the local definition of Sx(v), Sy(v).
Must be consistant with all upward local definitions.
#11 Опубликовано: 13.09.2016 15:53:06
You're welcome.
The main change was this:
Actually I'm not sure why calculation of u is so complex... looks like it is just a copy of m.
#12 Опубликовано: 14.09.2016 00:51:51
Quite right Andrey: 'u' is 'm', which 'm' is redundant.
I must have constructed N_(v,j) aroud 'u' from some source,
thus easier to check the coding. The attached work sheet
has been refactored with auxilliary explanations.
Can be used as model for DeBoor, pretty easy to adapt to
any project. Spline order is linear interpolation around
the polygon. Spline order 2 is "convex hull" per say.
They are about the only two types splines useful for
technical works [?]
Spline De Boor [Loop].sm (41,68 КиБ) скачан 1240 раз(а).
