DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Mensajes
Functions list:
dn_AdamsMoulton(4) - (ode,y(x),xmax,steps) uses the Adams-Moulton method.
dn_AdamsMoulton(5) - (ics,xmin,xmax,steps,D(x,y)) uses the Adams-Moulton method.
dn_ExplicitRK45(3) - (ode,y(x),xmax) uses the explicit Runge-Kutta (4)5 method.
dn_ExplicitRK45(4) - (ode,y(x),xmax,steps) uses the explicit Runge-Kutta (4)5 method.
dn_ExplicitRK45(5) - (ics,xmin,xmax,steps,D(x,y)) uses the explicit Runge-Kutta (4)5 method.
dn_GearsBDF(3) - (ode,y(x),xmax) uses the Gear’s BDF method.
dn_GearsBDF(4) - (ode,y(x),xmax,steps) uses the Gear’s BDF method.
dn_GearsBDF(5) - (ics,xmin,xmax,steps,D(x,y)) uses the Gear’s BDF method.
dn_ImplicitRK5(3) - (ode,y(x),xmax) uses the implicit Runge-Kutta 5 method.
dn_ImplicitRK5(4) - (ode,y(x),xmax,steps) uses the implicit Runge-Kutta 5 method.
dn_ImplicitRK5(5) - (ics,xmin,xmax,steps,D(x,y)) uses the implicit Runge-Kutta 5 method.
dn_LinAlgEigenvalues(1) - ( A ) computes the eigenvalues of a square matrix (general, symmetric, symmetric band and complex general matrices).
dn_LinAlgEigenvectors(1) - ( A ) computes the eigenvectors of a square matrix (general, symmetric, symmetric band and complex general matrices).
dn_LinAlgLLS_COF(2) - ( A, B ) computes the minimum-norm solution to a real linear least squares problem. Using a omplete orthogonal factorization of A.
dn_LinAlgLLS_QRorLQ(2) - ( A, B ) computes the minimum-norm solution to a real linear least squares problem. Using a QR or LQ factorization of A.
dn_LinAlgLLS_SVD(2) - ( A, B ) computes the minimum-norm solution to a real linear least squares problem. Using the singular value decomposition of A.
dn_LinAlgSolve(2) - ( A, B ) computes the solution to a real system of linear equations (general, band and tridiagonal matrices): A * X = B.
dn_LinAlgSVD(1) - ( A ) computes the singular value decomposition (SVD) of a real M-by-N matrix: A = U * S * transpose(V).
dn_MatrixInverse(1) - ( A ) calculate the inverse matrix.
Differential Equations. Initial-value problem for nonstiff and stiff ordinary differential equations ODEs (explicit Runge-Kutta, implicit Runge-Kutta, Gear’s BDF and Adams-Moulton).
Solvers for Non-Stiff Systems:
dn_AdamsMoulton(init, x1, x2, intvls, D) solves an initial-value problem for nonstiff ordinary differential equations using the Adams-Moulton method.
dn_ExplicitRK45(init, x1, x2, intvls, D) solves an initial-value problem for nonstiff ordinary differential equations using the explicit Runge-Kutta method of order (4)5.
Solvers for Stiff Systems:
dn_ImplicitRK5(init, x1, x2, intvls, D) solves an initial-value problem for stiff ordinary differential equations using the implicit Runge-Kutta method of order 5.
dn_GearsBDF(init, x1, x2, intvls, D) solves an initial-value problem for stiff ordinary differential equations using the Gear’s BDF method.
Arguments:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
Options:
- AbsTol - absolute tolerance parameter, default value 10⁻⁷.
- RelTol - relative tolerance parameter, default value 10⁻⁴.
Links:
1. DotNumerics is a website dedicated to numerical computing for .NET. DotNumerics includes a Numerical Library for .NET. The library is written in pure C# and has more than 100,000 lines of code with the most advanced algorithms for Linear Algebra, Differential Equations and Optimization problems. The Linear Algebra library includes CSLapack, CSBlas and CSEispack, these libraries are the translation from Fortran to C# of LAPACK, BLAS and EISPACK, respectively.
2. Arenstorf orbit. Numerical Analysis: Theory and Applications. Proseminar, 28.03.2011, UIBK [pdf].
3. How to find spatial periodic orbits around the Moon in the TBP.
Books:
1. Solving Ordinary Differential Equations II: Stiff and Differential-Algebraic Problems.
Examples:
dn.ode.kinetic1.sm (8,26 KiB) descargado 2009 vez(es).
dn.ode.kinetic2.sm (12,59 KiB) descargado 1876 vez(es).
dn.ode.kinetic3.sm (12,28 KiB) descargado 1949 vez(es).
dn.ode.test1.sm (19,58 KiB) descargado 1953 vez(es).
dn.ode.test2.sm (18,88 KiB) descargado 1932 vez(es).
dn.ode.Amplitude detector.sm (20,17 KiB) descargado 1981 vez(es).
dn.ode.kinetic1.pdf (77,42 KiB) descargado 1102 vez(es).
dn.ode.kinetic2.pdf (93,05 KiB) descargado 1032 vez(es).
dn.ode.kinetic3.pdf (91,31 KiB) descargado 1023 vez(es).
dn.ode.test1.pdf (115,72 KiB) descargado 1007 vez(es).
dn.ode.test2.pdf (120,44 KiB) descargado 989 vez(es).
dn.ode.Amplitude detector.pdf (148,87 KiB) descargado 1043 vez(es).
See also:
● [topic=726]Mathcad Toolbox[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=17067]lsoda[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
DorNumerics. ODE. Arenstorf orbit.sm (91,95 KiB) descargado 1804 vez(es).
WroteThank you uni,
dn_GearsBDF might be the ODE solver of choice for SMath. I would not mind some more solvers as well![]()
Updated. dn_AdamsMoulton(), dn_ExplicitRK45(), dn_ImplicitRK5() added.
In Russia we say: получите, распишитесь.
If you are by any chance here on Thassos-Greece (I am here with my family on the vacation) just let me know and come for a beer
I am just curious how is the numerical accuracy controlled in all your solvers? There is no any additional parameter about this, or I was wrong about it?.
WroteYou're a lucky man, on Greek island with beer and I'm in Siberia with the bears
WroteBy the way uni,
For all methods the following values:
RelTol = 1.0E-4,
AbsTol = 1.0E-7
I will add the ability to change it. I think, using variables in the document: RelTol and AbsTol.
WroteWroteYou're a lucky man, on Greek island with beer and I'm in Siberia with the bears
Just imagine how different we are?. My "Lord of the ring" bring us here - me and our children, and I am most interested to "chat" here with you about the ODE solvers
WroteWroteBy the way uni,
RelTol = 1.0E-4,
AbsTol = 1.0E-7
I must be annoying now
WroteWroteWroteBy the way uni,
RelTol = 1.0E-4,
AbsTol = 1.0E-7
I must be annoying now, but could you try please try to reduce this numbers just a bit and try my "famous" example with bioreactions. I used recently some ODE stiff solvers from a package inside R. They gave the same results with negative concentration. Then, I reduced the default values for the accuracy and it worked a bit longer, but gave me the expected zero concentration.
Updated. I've added support for accuracy (not completely). The library allows to set accuracy for each equation separately. Now for all the equations will be the same accuracy.
WroteWroteWroteWroteBy the way uni,
RelTol = 1.0E-4,
AbsTol = 1.0E-7
Yes ...
WroteHi Uni,
I've seen you can play the magician and make people's dreams to come true.
I have such a modest dream – ta have available in SMath some others modules from DOTNUMERICS, particularly the EISPACK one.
If my gentle request is not too abusive, please let me know how to address this package.
Please accept my wishes for an agreeable summer.![]()
The same greetings for all the forum members and particularly to Andrey!
Ioan
Well, if that's possible, I'll do it. Thank you.
[+]: dn_LinAlgSolve(), dn_LinAlgLLS_COF(), dn_LinAlgLLS_QRorLQ(), dn_LinAlgLLS_SVD(), dn_LinAlgSVD(), dn_LinAlgEigenvalues(), dn_LinAlgEigenvectors(), dn_MatrixInverse().
CitarI have such a modest dream – ta have available in SMath some others modules from DOTNUMERICS, particularly the EISPACK one.
What kind of functions do you need?
I'm not sure that dn_LinAlgEigenvalues() works correctly.
DotNumerics. Linear Algebra. Example 1.sm (28,95 KiB) descargado 1819 vez(es).
I played a bit with your example. It seems to me that eigenvalues and eigenvectors are correct for both matrices A and F. For the matrice F you gave the vector of eigenvalues which should be correct ("must be" vector). It seems that both vectors of eigenvalues - this one and the one found by dn_LinAlgEigenvalues() correspond to the eigenvectors fond by dn_LinAlgEigenvectors(). I am not sure this should be all right then or some numerical "glitch" is involved here. For some simpler matrices it works Ok and we can get the desired result by simple transformations of eigenvectors. I do not know how the AlgLib works and which kind of transformtion uses in order to give one of the many possible solutions for eigenvectors. I might be wrong about all of this, of course.
This time again eval() must be used as well to get the result. Moreover, again the well known annoying thing that sometimes the results with and without eval() are slightly different. See the attached file please.
DotNumerics_LinearAlgebra_Example-corr.sm (106,57 KiB) descargado 1800 vez(es).
DotNumerics. Linear Algebra. Example 2.sm (11,82 KiB) descargado 1821 vez(es).
dn_AdamsMoulton.test1.sm (11,33 KiB) descargado 1751 vez(es).
dn_AdamsMoulton.test1.pdf (48,2 KiB) descargado 878 vez(es).
