DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - Mensajes
Simple test 2.
DotNumerics.ode.test2.sm (21,23 KiB) descargado 1761 vez(es).
DotNumerics.ode.test2.pdf (79,99 KiB) descargado 876 vez(es).
WroteSimple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24,51 KiB) descargado 1855 vez(es).
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23,66 KiB) descargado 1911 vez(es).
Updated for SS 0.99.6824. Intervals issue fixed.
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
Changes:
Updated.
dn.ode.kinetic1.sm (8,26 KiB) descargado 2009 vez(es).
dn.ode.kinetic2.sm (12,59 KiB) descargado 1877 vez(es).
dn.ode.kinetic3.sm (12,28 KiB) descargado 1951 vez(es).
dn.ode.test1.sm (19,58 KiB) descargado 1953 vez(es).
dn.ode.test2.sm (18,88 KiB) descargado 1932 vez(es).
dn.ode.Amplitude detector.sm (20,17 KiB) descargado 1982 vez(es).
dn.ode.kinetic1.pdf (77,42 KiB) descargado 1103 vez(es).
dn.ode.kinetic2.pdf (93,05 KiB) descargado 1032 vez(es).
dn.ode.kinetic3.pdf (91,31 KiB) descargado 1023 vez(es).
dn.ode.test1.pdf (115,72 KiB) descargado 1007 vez(es).
dn.ode.test2.pdf (120,44 KiB) descargado 989 vez(es).
dn.ode.Amplitude detector.pdf (148,87 KiB) descargado 1043 vez(es).
A 4 usuarios les gustó este mensaje
NDTM Amarasekera 24/12/2018 9:44:00, sergio 24/12/2018 11:04:00, frapuano 24/12/2018 14:23:00, Radovan Omorjan 24/12/2018 14:52:00
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8,42 KiB) descargado 1761 vez(es).
Вячеслав Мезенцев 22/8/2022 3:11:00
