text in if statements
text in if statements - Mensajes
#1 Publicado: 1/5/2019 17:40:54
The Cross
The Cross
0 me gusta en 73 mensajes.
Can text be included in an if statement? For example:
If "Thin-walled pipe anchored throughout" then P=1-v.
I have various conditions that different formulas would be used depending on the conditions, see below.restraints.png
#2 Publicado: 1/5/2019 18:24:24
Hi. You have some options for do that. Here are two:
#3 Publicado: 1/5/2019 22:04:46
You have some options for doing that.
Easy to complete the conditions, thus the project.
Cheers Alvaro ... Jean
#4 Publicado: 2/5/2019 17:41:07
The Cross
The Cross
I don't understand how to input the data into the statement. If I press the space key, the input ends, and I cannot input anything.
#5 Publicado: 2/5/2019 17:47:44
There is no space key to press. Construct the snippet, done.
#6 Publicado: 2/5/2019 18:04:03
The Cross
The Cross
Sorry, I have never constructed a snippet before. How do I do that?
#7 Publicado: 2/5/2019 19:05:13
Construct the math regions as per the image that we call snippet.
#8 Publicado: 3/5/2019 10:15:42
The Cross
The Cross
I tried to construct it. My question is how to do that. I try and the below is what happens:if statement.png
#9 Publicado: 3/5/2019 13:09:07
g(str,x):=then from menu f(x), then cases, then fill-in
#10 Publicado: 3/5/2019 14:11:45
fedeghi
fedeghi
25 me gusta en 112 mensajes.
The cases() function is included into the "custom functions" plugin, so you should also be sure to have it installed.
frapuano 3/5/2019 14:38:00
#11 Publicado: 3/5/2019 16:16:46
The Cross
The Cross
Thank you. I had the "custom functions" plugin installed, but the use of it is not in any of the manuals, at least not that I could find. I had no idea I had to type the word "cases" to get to the input.
#12 Publicado: 3/5/2019 16:19:43
The Cross
The Cross
Thank you. I understand now.
#13 Publicado: 3/5/2019 17:37:20
only click the function 'cases' from the f(x) menu.
In the right most place holder of the first 'if'
place the cursor type coma, coma [,,]
that gives another line of conditions ... and so on.
#14 Publicado: 3/5/2019 17:48:24
The Cross
The Cross
Thank you. I was trying to figure out how to do that.
#15 Publicado: 7/5/2019 13:15:44
The Cross
The Cross
I use the cases function to type everything in, but when I go back to the first line that says "x if str", as soon as I type "x if str =, as soon as I type the = sign, I get "x not defined". I am trying to understand, but not getting it yet. I had it almost working, but then this glitch appeared.
#16 Publicado: 7/5/2019 13:39:45
The Cross
The Cross
I figured out how I did it before. I cannot type the = in the above, but it works with a :=. But it does not really work, because if I say str:="b" and x:=7, the answer is 21.99 instead of 14, but it does allow me to type it. I am confused.
#17 Publicado: 7/5/2019 14:54:10
#18 Publicado: 7/5/2019 15:18:13
Grupo: Moderator
Please post the worksheet or a screenshot. In the second column of cases you have to use boolean equals, not the assignment operator.
You can find the boolean operators in one of the palettes on the right of your screen, hovering the mouse hover the symbols you should see the keyboard shortcut.
#19 Publicado: 7/5/2019 15:26:07
The Cross
The Cross
thank you. I can't use the "Thank" button because every time I do, it says "error occurred"
#20 Publicado: 7/5/2019 15:31:51
The Cross
The Cross
How do I remove a line. I tried backspacing, and it did not work.
