Conditionally Formatted Labels
Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Mensajes
#1 Publicado: 30/9/2013 10:46:40
Grupo: Moderator
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
Hi all,
Here there is a plugin to add labels customizable by canvas inputs.
Plugin languages: English Italiano
  • requirements: SMath Studio 0.96.5146 Nigthly build or later, .Net Framework 2.0;
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: download and unzip the attached archive;
  • languages: if you want to have a new UI language look into the documentation's Language folder
>>> PLEASE REPORT IN THIS THREAD ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabel |  NumericUpDown | PathPicker | RadioButtonList | Slider
CFLabelRegion_docs.7z (83,68 KiB) descargado 1822 vez(es).
A 7 usuarios les gustó este mensaje
studoc 16/12/2015 4:31:00, Вячеслав Мезенцев 30/9/2013 12:10:00, sergio 30/9/2013 13:21:00, Martin Kraska 30/9/2013 14:13:00, ioan92 1/10/2013 3:45:00, Andrey Ivashov 26/10/2013 8:10:00, Radovan Omorjan 30/9/2013 11:24:00
#2 Publicado: 30/9/2013 11:28:24
Grupo: Moderator
This is nice Davide, thank you
By the way, we can suppress viewing the if statement (only the formated label) by right click and unchecking "Display input data"
#3 Publicado: 30/9/2013 12:30:11
Grupo: Moderator
You're right Radovan, and you can also nest many if/else to have multiple outputs
#4 Publicado: 30/9/2013 13:28:28
127 me gusta en 342 mensajes.
thanks Davide,
but I can't resize the label despite the presence of grip
Win64
Portable Version Smath 0.96 (build 4909)
#5 Publicado: 30/9/2013 14:12:09
Grupo: Moderator
thanks Davide,
Win64
The size is exclusively driven by the contents (string length). Might be a good idea to hide the grips.
Please find attached a brick for bar charts. Please note that I was forced to fill the right of the bar by visible symbols as spaces obviously are disregarded for computing the region size.
Example cfregion barchart.sm (4,95 KiB) descargado 2095 vez(es).
Radovan Omorjan 30/9/2013 14:51:00
#6 Publicado: 30/9/2013 14:39:22
Grupo: Moderator
Correct, this is by design - like for hyperlink regions
I know, but is not yet possible; Andrey know this issue, the behavior will change in future
I can force the plugin to measure also the trailing spaces, if could be useful, just let me know it
best regards,
Davide
2013-09-30 20_38_18-SMath Studio Desktop - [Example cfregion barchart.sm].png
Radovan Omorjan 30/9/2013 14:52:00
#7 Publicado: 30/9/2013 15:04:25
Grupo: Moderator
Done, updated
Martin Kraska 30/9/2013 15:23:00
#8 Publicado: 30/9/2013 15:38:42
Grupo: Moderator
Now the complete bar chart.
Davide Carpi 30/9/2013 17:17:00, Radovan Omorjan 1/10/2013 4:46:00
#9 Publicado: 1/10/2013 10:08:16
Grupo: Moderator
UPDATED
- works in Smath Viewer;
- default background color (empty string): white;
- default foreground color (empty string): black.
Martin Kraska 2/10/2013 3:56:00
#10 Publicado: 2/10/2013 4:22:38
Grupo: Moderator
Thanks for the update.
As you see, the region can display multiline text, thus it would be possible to do stuff like the bar chart in a single region, if there was access to the newline character from the GUI.
I'd propose to accept a single string as argument, now as there are defaults for the colors.
I also propose to left align the text (or to provide optional control)
#11 Publicado: 2/10/2013 4:43:53
Grupo: Moderator
Hi Martin,
I see, I'll think about to add more controls... as general idea this region is thinked to be used as a label (a short text) with variable appearance depending on the script events; the table region will be the better solution to have a more customizable (fixed) appearance.
BTW your last example puts me in mind that would be more handy and useful to use the built-in Output window to easily access these infos without calling dedicated functions or looking for log files.
#12 Publicado: 2/10/2013 6:05:31
Grupo: Moderator
Off-spec use of features is part of the fun, isn't it?
I suppose your proposal impies that the output window can be fed directly from inside plugins. How would I trigger this from outside? How do I identify the output of a particular math region in the midst of a SMath sheet? I can't stop the re-calculation of a sheet at a particular expression, can I?
The maxima plugin has a two-level log inspection feature:
  1. MaximaLog("all" ) displays the entire Maxima session from the Maxima perspective without translation detail)
  2. MaximaLog(#) displays the detail of the previous Maxima call including maxima command, maxima response and back-translation.
By positioning the MaximaLog(#) at the right place you can clearly tell what Maxima did in the last interaction, regardless if the call was made by a hijacked function like int(), diff(), sum() or lim(), a dedicated function like Solve() or LinSolve() or directly by a Maxima() command.
I found MaximaLog(#) handy to use for documenting bugs in the todo list and it is always close at hand (from the dynamic assistant) in the sheet without the need to open and close the output window.
I must admit that I don't know how to even reach this level of comfort and clearness using the output window. How would you control the output if not by dedicated commands? How would you identify where the output came from? When using trace(), I find myself adding label texts to output commands in order to match the output with the SMath context. But I may just oversee options, thus any ideas are welcome.
#13 Publicado: 2/10/2013 6:35:07
Grupo: Moderator
Not always (for the developpers) :-p
The multiline feature is not easily accessible from the canvas, so the alignment feature would produce confusion (in some way like the resize's grips); BTW if you want a "display region" to send out a well formatted output from the Maxima plugin, you can also make something like the "Maple" region of Viacheslav
Sincerely I don't know, I've threw a stone into the pond
Maybe a special context menu item could be added or a log function with canvas free result that enable the output window output, or something else
BTW looking back my previous post Log files are useful for crashes (deep debugging -> plugin's developpers)
#14 Publicado: 4/10/2013 15:16:41
Grupo: Moderator
UPDATED
- Fixed regional settings issues with Font sizes (comma decimal separator related*)
* Martin's activebook svn file updated
Martin Kraska 4/10/2013 15:36:00
#15 Publicado: 4/10/2013 15:35:37
Grupo: Moderator
Great, thanks. I also updated the barchart example.
#16 Publicado: 25/10/2013 11:39:06
Grupo: Moderator
UPDATED
- small fixes
- added styles (optional 4th argument)
Andrey Ivashov 26/10/2013 8:22:00
#17 Publicado: 2/2/2014 19:56:29
Grupo: Moderator
UPDATED
- SMath Studio 0.96.5146 required
best regards,
Davide
ioan92 3/2/2014 15:28:00, Andrey Ivashov 2/2/2014 21:01:00
#18 Publicado: 5/2/2014 4:22:07
kaaden
kaaden
0 me gusta en 13 mensajes.
Hello !
Where can I download the Formatting Label for 4909 versión?
with new version I can´t open old snippets
#19 Publicado: 5/2/2014 4:46:51
Grupo: Moderator
Hello !
You can use the portable version provided by mkraska (here) directly or copying the plugin from that distribution to your %APPDATA% folder
#20 Publicado: 5/2/2014 5:18:01
kaaden
kaaden
thanks
I download from here
https://smath.com/wiki/SMath%20with%20Plugins.ashx
