Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Mensajes
Here it is.
losa-forum.sm (862,11 KiB) descargado 1912 vez(es).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
WroteHere it is.
Document does not open ... incorrect format
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/es-ES/files/Download/EWoMa6/2023-01-17-15_10_16-SMath-Solver---[losa-forum.sm_].png)
The same happens if you try to force a numerical evaluation using eval()
![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/es-ES/files/Download/uxxyYx/2023-01-17-15_23_37-SMath-Solver---[losa-forum.sm_].png)
WroteSMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
WroteThat is it!
As allways thanks!!
You're welcome!
WroteBut still don't understand why Jean files fails.
If you remove the 3 inline evaluations it will work.
![2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png](/es-ES/files/Download/8DEVaV/2023-01-17-16_28_05-SMath-Solver---[Image-Formated-LABEL-[Oxyhemoglobin]-FORUM.sm].png)
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter.nevermind I was looking at your file.
My file can be an example of things NOT to do.
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5,47 KiB) descargado 1873 vez(es).
kind regards
Thank you very much.
This is exactly what I needed.
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
WroteI'm looking for a way to represent the letter D as a subscript
You can subscribe whatever.
mysystem dot HelloGrandMa
WroteWroteI'm looking for a way to represent the letter D as a subscript
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
Oscar
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6,22 KiB) descargado 1852 vez(es).
Oscar Campo 17/10/2023 16:52:00
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10,73 KiB) descargado 1875 vez(es).
WroteSubscripts in native Solver 30405.
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
![2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png](/es-ES/files/Download/2aoqAw/2023-10-14-18_53_23-SMath-Solver---[Conditionally-Formatted-Labels_unity.sm_].png)
