DISLIN
DISLIN - A high-level plotting library for displaying data - Mensajes
#1 Publicado: 14/2/2016 5:58:08
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
DISLIN 11.5
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources EULA
DISLIN is a high-level plotting library for displaying data as curves, polar plots, bar graphs, pie charts, 3D-color plots, surfaces, contours and maps.
Note: Paths to image and temp files must exist. Use double slashes ( '\\' ) for DISLIN functions.
Click to enlarge Click to enlarge Click to enlarge Click to enlarge Click to enlarge
Examples:
DISLIN. Example 1.sm (95,34 KiB) descargado 2190 vez(es).
DISLIN. Example 1.pdf (287,2 KiB) descargado 1508 vez(es).
DISLIN. Example 2.pdf (235,04 KiB) descargado 1140 vez(es).
DISLIN. Example 2.sm (122,79 KiB) descargado 2002 vez(es).
DISLIN. Example 3.pdf (954,31 KiB) descargado 1208 vez(es).
DISLIN. Example 3.sm (308,64 KiB) descargado 2006 vez(es).
DISLIN. Example 4.sm (86,15 KiB) descargado 1943 vez(es).
DISLIN. Example 4.pdf (233,03 KiB) descargado 1133 vez(es).
DISLIN. Example 5.sm (119,81 KiB) descargado 2023 vez(es).
DISLIN. Example 5.pdf (430,99 KiB) descargado 1117 vez(es).
DISLIN. Example 6.sm (202,78 KiB) descargado 1900 vez(es).
DISLIN. Example 6.pdf (657,16 KiB) descargado 1308 vez(es).
Links:
1. DISLIN Web site .
2. DISLIN HTML Manual. Contents .
3. Appendix D. Index .
4. A General-Purpose Scientific and Engineering Plotting Library that Includes Smith Charts (PDF file) by Dr. Scott Best from SiberSci, LLC.
Radovan Omorjan 14/2/2016 7:33:00, ioan92 14/2/2016 8:01:00, Davide Carpi 14/2/2016 8:05:00
#2 Publicado: 14/2/2016 13:32:20
Grupo: Moderator
A complete set of plots in a single plugin, this is wonderful
I cannot evaluate the functions, seems something is missing
#3 Publicado: 14/2/2016 13:46:46
Grupo: Moderator
Make sure to use the latest version. Restart SMath Studio if functions unavailable. Turn off autocalc mode.
Something wrong with the SMath Studio I think, there is no working example because I can't save the worksheet. But if you want to try I can get the list of functions which was used in my example (you must manually enter each function ([Ctrl+C] [Ctrl+V]) and press equal sign).
Test example:
dislin.metafl("svg"
dislin.setfil("d:\\file.svg"
dislin.errdev("FILE"
dislin.errfil("d:\\out.txt"
dislin.filmod("DELETE"
dislin.disini(0)
dislin.disfin(0)
N:50
for(n,range(1,N),line(el(x,n):{2*π}/N*(n-1),el(y1,n):sin({2*π}/N*(n-1)),el(y2,n):cos({2*π}/N*(n-1)),3,1))
dislin.metafl("svg"
dislin.units("INCH"
dislin.page(800,600)
dislin.disini(0)
dislin.reset("ALL"
dislin.pagera(0)
dislin.complx(0)
dislin.chacod("UTF8"
dislin.axspos(100,520)
dislin.axslen(650,400)
dislin.name("Ось X","X"
dislin.name("Ось Y","Y"
dislin.labdig(1,"X"
dislin.ticks(5,"XY"
dislin.titlin("Пример работы с графиками",1)
dislin.titlin("Функции: sin(x), cos(x)",3)
dislin.linmod("ON","SMOOTH"
dislin.graf(0,2*π,0,π/4,-1,1,-1,0.5)
dislin.color("blue"
dislin.curve(x,y1,N)
dislin.color("red"
dislin.curve(x,y2,N)
dislin.color("fore"
dislin.title(0)
dislin.dash(0)
dislin.grid(1,1)
dislin.solid(0)
dislin.xaxgit(0)
dislin.disfin(0)
EDIT: Tested only with Win x32. Don't forget to show log.txt (in the plugin directory: 23831ed7-5051-46d5-aaa8-b2fb40002ec1\x.x.x.x\) if something not working.
ioan92 14/2/2016 14:02:00, Davide Carpi 14/2/2016 14:49:00
#4 Publicado: 14/2/2016 14:49:05
Grupo: Moderator
Thank you Viacheslav, disabling the recalculation I can save your example and I experienced some small improvements (still doesn't works):
Files (worksheet, log, output svg): DISLIN.zip (19,63 KiB) descargado 610 vez(es).
"Functions not defined":
Aside note, crash occours if the output directory doesn't exists;
#5 Publicado: 14/2/2016 15:01:02
Grupo: Moderator
I forgot to say that you should not save the file! Look at the contents. Function names lost prefix. Therefore it is necessary to follow exactly what I write.
1. Restart SMath Studio.
2. Turn off autocalc.
3. Do not save the worksheet!
4. Enter functions line by line, don't forget to add = (do not press F9!).
dislin.metafl("svg"
dislin.errdev("file"
dislin.filmod("delete"
dislin.disini(0)
dislin.disfin(0)
5. Now you can press F9.
EDIT: The library interface is ugly. You must read the user manual before continuing experiments. The order of calling functions is important.
ioan92 14/2/2016 16:03:00, Davide Carpi 14/2/2016 18:51:00
#6 Publicado: 14/2/2016 16:50:06
Grupo: Moderator
There is a bug in SMath Studio I think, we must wait until Andrey say something about saving function names with points. As for file names, you can use any with some rules. One of them - double slash. I use Image Region plugin for visualization, you can use not only svg but other formats too: png, ... (see online help).
ioan92 14/2/2016 17:04:00
#7 Publicado: 14/2/2016 17:01:08
Alexander O. Melnik
Alexander O. Melnik
127 me gusta en 498 mensajes.
Grupo: Moderator
Uni, great work! Looks like we just might get the right plotting tool in SMath.
Do you think you might have time to integrate DISLIN into a stand alone region?
If you do so, you might get around the function saving bug (since functions will not be exposed to SMath directly), and more importantly, to incorporate all the formatting options into a settings menu instead of typing them one-by-one.
Thank you for your hard work and time spent
#8 Publicado: 14/2/2016 17:38:23
Grupo: Moderator
Yes, like in assembler it is hard to write what you want. DISLIN is a graphical assembler which contain 777 functions now. It is possible to write some wrapper for it or make a stand alone region but in these directions will be lost some original functionality. I created this plugin only for 3D plotting but after several experiments I see what these functions have a strange behavior with hidden lines. The result image has artifacts.
ioan92 14/2/2016 17:40:00, Davide Carpi 14/2/2016 18:51:00
#9 Publicado: 24/2/2016 13:32:12
Grupo: Moderator
Updated. Problem fixed. Thanks to Andrey for the explanation.
DISLIN. Example1.sm (123,61 KiB) descargado 1892 vez(es).
DISLIN. Example1.pdf (155,58 KiB) descargado 1173 vez(es).
Davide Carpi 25/2/2016 7:14:00
#10 Publicado: 24/2/2016 13:58:44
Grupo: Moderator
DISLIN 0.1.5898.14938 ?
#11 Publicado: 24/2/2016 14:08:58
Grupo: Moderator
This is because of other program settings. I'll fix it now.
ioan92 24/2/2016 14:11:00, Davide Carpi 25/2/2016 7:14:00
#12 Publicado: 24/2/2016 14:26:37
Grupo: Moderator
Updated. Try now.
Davide Carpi 25/2/2016 7:14:00, ioan92 24/2/2016 14:33:00
#13 Publicado: 24/2/2016 14:50:42
Grupo: Moderator
Later I'll try to show some examples. DISLIN collection is not fully implemented and I will try to solve this.
Online Manual
Davide Carpi 25/2/2016 7:14:00, ioan92 24/2/2016 14:54:00
#14 Publicado: 24/2/2016 16:53:36
frapuano
frapuano
13 me gusta en 115 mensajes.
Strange on my system Smath crashes and I am forced to close the program.
The release installed is
Working under Windows 7 Professional
Franco
#15 Publicado: 24/2/2016 18:02:35
frapuano
frapuano
You mean to uninstall all Smath even if I am using actually an updated version of Smath portable.
Franco
#16 Publicado: 25/2/2016 0:47:59
Alexander O. Melnik
Alexander O. Melnik
Grupo: Moderator
I confirm SMath crash trying to open DISLIN.Example1.sm
#17 Publicado: 25/2/2016 2:25:01
Grupo: Moderator
I have Windows 7 Ultimate x64 and it works fine for me. Show me log.txt (in plugin folder). Maybe environment variable TEMP points to a long path and DISLIN can't get access to the temporary folder. My TEMP=C:\Temp
This is just a guess.
#18 Publicado: 25/2/2016 6:37:10
frapuano
frapuano
Uninstalled everything using Windows uninstall , then deleted Smath directory and other directories linked to Smath (I guess).
Reinstalled again downloading the last release from the site ...same result ( I haven't restarted the LT in between ) .
The example file loads and after a little bit comes up the screen with : Smath Studio Desktop has stopped working ..
Moreover I do not find any log.txt in the plugin folder and any dslin.something else anywhere on my computer ...make me wonder if the DSLIN plug in has been really downloaded and stored somewhere.
Franco
#19 Publicado: 25/2/2016 7:39:44
Grupo: Moderator
Confirmed, as stated previously the crash is due to directory management.
You have to disable the auto recalculation, open the worksheet, change the directories, and then you can run the example provided by Viacheslav.
Log file is available only if SMath is running, deleted after closing.
Вячеслав Мезенцев 25/2/2016 8:27:00, ioan92 25/2/2016 11:35:00
#20 Publicado: 25/2/2016 8:53:16
frapuano
frapuano
Davide
Doing as you suggest and renaming the files to c:\file.svg and c:\out.txt ( on my computer and using a double \\ in the DSLIN command ) creates the output file and I am able to read the svg file in Inkscape ...I have still problem due to my ignorance of the new Image region to visualize it in Smath ..but hope soon or later to succeed.
Thanks a lot and best regards
Franco
