the function dec2bin ()
the function dec2bin () - Mensajes
#1 Publicado: 8/11/2009 10:18:25
qanniu
qanniu
0 me gusta en 3 mensajes.
hi ,i'm just find smath today.i want to know is there some function like dec2bin or hex2bin...smath can you tell me thanks.
#2 Publicado: 8/11/2009 22:53:16
Grupo: Super Administrator
No. Program have no these functions, but they will be implemented.
#3 Publicado: 9/11/2009 0:35:21
qanniu
qanniu
thanks,hehe.i'was finding the function all the days yesterday.by the way ,it is morning in China.
#4 Publicado: 26/12/2022 21:40:39
Mark R Harris
Mark R Harris
5 me gusta en 90 mensajes.
Epic dredge sorry. Functional, with all credit to @Razonar (source/author).
20221227 Dec2bin.sm (4,5 KiB) descargado 1720 vez(es).
Also needed:
* set string length (ie leading zeros), and
* functions for bit field testing.
#5 Publicado: 27/12/2022 17:14:06
Thanks, nice source code.
algo(col) was designed to recover matrix col(s) string(s) to values.
Maths Convert-dec2bin.sm (18,88 KiB) descargado 1610 vez(es).
#6 Publicado: 27/12/2022 18:19:56
Mark R Harris
Mark R Harris
The source was repurposed from Razonar.
Interesting, thanks Jean.
Do you know a way to implement a fixed 9-bit binary counter in SMath (or display a decimal counter in fixed-length binary)? This is probably a bit too esoteric to be a feature request...
#7 Publicado: 29/12/2022 10:46:20
Sorry Collab: I have no idea yet how to counts pulse.
From recollection, such demand was not honored.
#8 Publicado: 29/12/2022 11:50:13
Grupo: Moderator
If I understood correctly;
You want a 9bit binary representation similar to 8084 cpu registers.
I must admit it is a highly specific request.
registers
#9 Publicado: 29/12/2022 13:07:13
That comes easily ... ?
#10 Publicado: 29/12/2022 15:04:28
Mark R Harris
Mark R Harris
Thanks Jean, greatly appreciated.
I should have been more clear in my request.
I'm after a 9-bit long bit-field count that I can test each bit (ie each bit has a 2^n position in the whole count) so that as the count progresses. This way each of the 9 tests will have been performed half the tests in the 0 branch and half in the 1 branch.
If it is 0 then do x, otherwise do y type of thing.
The application is worst-case circuit analysis: https://k6jca.blogspot.com/2012/07/monte-carlo-and-worst-case-circuit.html
Half the tests with the +% tolerance applied the other half with the -ve tolerance applied.
#11 Publicado: 29/12/2022 15:12:34
Mark R Harris
Mark R Harris
registers
Very close, thanks overloard.
I'm after an asynchronous 9-bit ripple-style counter that I can bit-test (or equivalent) 9 times during each loop, each time to do one of two actions half the time (ie calculated with each extreme of the tolerance) for worst-case circuit analysis.
This may be better achieved via dec2bin() with a constant 9-bit length output so that the 2^n check work consistently (ie string position tests).
FYI (reference only): https://k6jca.blogspot.com/2012/07/monte-carlo-and-worst-case-circuit.html. The need is for X-Y style visualization that LTSpice can't provide.
#12 Publicado: 29/12/2022 15:39:13
Hi. Something like this?
bin_counter.sm (9,7 KiB) descargado 1627 vez(es).
Mark R Harris 29/12/2022 15:47:00
#13 Publicado: 29/12/2022 15:40:56
Mark R Harris
Mark R Harris
Modification of Razonar's dec2bin() should work well.
dec2bin(p,q) where p is the bit-field length and q is the decimal number to be converted.
Check the converted string's length and then pad the front with zeros to suit.
#14 Publicado: 29/12/2022 15:44:09
Mark R Harris
Mark R Harris
Cripes Alvaro. Good to see your 'calibrated-crystal-ball' and 'mind-reading skills' are as good as your awesome maths/coding skills!
#15 Publicado: 29/12/2022 20:46:04
Grupo: Moderator
Maybe this can be useful.
dec2bin.sm (3,8 KiB) descargado 1609 vez(es).
Mark R Harris 29/12/2022 21:03:00
#16 Publicado: 29/12/2022 21:04:15
Mark R Harris
Mark R Harris
Perfect! Thank you overlord
#17 Publicado: 29/12/2022 23:03:42
Mark R Harris
Mark R Harris
I spoke too soon! Bit-testing don't work so well on a string.
A much better idea is a column vector with each of the 9 (ie n#) elements being either a one or a zero.
#18 Publicado: 30/12/2022 5:09:06
Grupo: Moderator
This was what I coded first, after that I made it to string.
Here is what you have asked for.
dec2bin.sm (6,09 KiB) descargado 1592 vez(es).
Mark R Harris 30/12/2022 6:38:00
#19 Publicado: 30/12/2022 6:39:01
Mark R Harris
Mark R Harris
Thank you so much overlord, that is both elegant and perfect!
#20 Publicado: 30/12/2022 11:05:26
Maybe, that's what you are looking for ?
Maths Convert num2str EXTENDED.sm (6,72 KiB) descargado 1655 vez(es).
