num2str problem with sum
num2str problem with sum - BTS issue SS-43 - Messages
#1 Posted: 8/24/2013 1:42:23 AM
1,361 likes in 2,275 posts.
num2str() fails to convert a sum to a string. In the sum(1) example "syntax is incorrect", in the sum(4) example "n is not defined".
Edit: This is now BTS issue SS-43
#2 Posted: 8/24/2013 3:48:22 AM
127 likes in 342 posts.
I confirm and add some further example.
[albumimg]284[/albumimg]
[smath 0.96 (build 4884) W7 64bit]
#3 Posted: 9/20/2013 12:26:06 PM
This is the current state. sum() now can produce symbolic results.
num2str() should provide a string corresponding to the unevaluated expression if it cannot be evaluated.
