Beta: SMath Studio 0.99.7666 (27 December 2020) - Messages
Download
SMathStudioDesktop.0_99_7666.Mono.tar.gz (1.43 MiB) downloaded 3062 time(s).
SMathStudioDesktop.0_99_7666.Setup.msi (2.31 MiB) downloaded 5742 time(s).
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region.
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
paste.sm (3.79 KiB) downloaded 2383 time(s).
WroteBTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description.
Hello Alvaro.
Thank you! Will fix it asap.
Thanks,
Jason
WroteI'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error.
The reason of this error is the same as it is in the issue [USERLINK]Razonar[/USERLINK] mentioned above. Fixed now.
