Beta: SMath Studio 0.99.7666 (27 December 2020)
Beta: SMath Studio 0.99.7666 (27 December 2020) - Сообщения
#1 Опубликовано: 27.12.2020 11:07:36
2 343 сообщений из 4 044 понравились пользователям.
Группа: Super Administrator
Изменения, входящие в версию 0.99.7666
Улучшения
  • Support to format content fragments added in Text Region (font size, font family, font weight; font style, text decoration, text color, background color, lines interval, paragraphs in Document mode);
  • Added possibility to restore automatic line breaks mode in Text Region by doubleclick on resizer.
Исправления
  • Critical error happened sometimes when using Del keyboard button in Math Region fixed.
Разное
  • Smart auto replacement functionality implemented for Text Region in Document Mode (f.e. inserting --- finalized by Enter will be replaced with horizontal rule; filling in equation in text will be detected as well);
  • Horizontal/vertical align toolbar buttons made hidden in Document mode;
  • Refactoring.
Скачать
SMathStudioDesktop.0_99_7666.Mono.tar.gz (1,43 МиБ) скачан 3196 раз(а).
SMathStudioDesktop.0_99_7666.Setup.msi (2,31 МиБ) скачан 5906 раз(а).
6 пользователям понравился этот пост
NDTM Amarasekera 27.12.2020 11:27:00, IVR 27.12.2020 14:20:00, Вячеслав Мезенцев 27.12.2020 17:50:00, Martin Kraska 27.12.2020 18:55:00, sergio 28.12.2020 10:20:00, Igor Skarine 31.12.2020 20:03:00
#2 Опубликовано: 27.12.2020 18:54:30
Impressive progress, Andrey.
I think the math detection is a bit over-greedy. As soon as I type a hyphen, the preceeding word is taken as a variable name and a math region is embedded. Thus the only way to add a hyphen between two words is to embrace it with spaces and delete the spaces afterwards. I'd recommend to do the conversion when Enter is pressed. A second enter then would leave the embedded math region.
IVR 28.12.2020 07:22:00, Jason McCool 29.12.2020 11:21:00, Andrey Ivashov 27.12.2020 20:17:00
#3 Опубликовано: 27.12.2020 20:32:39
Thank you Martin very much for this suggestion!
I'm thinking about ways to make this detection more smart, more predictable to user and be easily cancelable (meaning it should be possible to cancel/undo it when it is done incorrectly or user wants to leave text as is). I have some thoughts about it, so yeah, this will be significantly improved.
Regards.
#4 Опубликовано: 27.12.2020 20:40:43
1 125 сообщений из 1 799 понравились пользователям.
Hi. Thanks for the new features. BTW I can't paste in a math region with description, this is: if x:=line(something) I can't paste inside the x body if it have description.
paste.sm (3,79 КиБ) скачан 2538 раз(а).
Andrey Ivashov 27.12.2020 21:09:00
#5 Опубликовано: 27.12.2020 21:09:11
Hello Alvaro.
Thank you! Will fix it asap.
#6 Опубликовано: 29.12.2020 11:30:25
Jason McCool
Jason McCool
9 сообщений из 78 понравились пользователям.
I'm getting an unhandled exception error when copying text regions by highlighting an existing text region and using the Control key + mouse to copy it. It does continue without crashing, and I can apparently copy by highlighting and using Ctrl-C and Ctrl-V, or by using the buttons on the menu bar. So far it only seems to be the Ctrl + mouse method of copying that used to work and doesn't in this build. Formulas still can be copied and pasted that way without error.
Thanks,
Jason
Andrey Ivashov 29.12.2020 16:18:00
#7 Опубликовано: 29.12.2020 16:19:33
Thank you!
The reason of this error is the same as it is in the issue [USERLINK]Razonar[/USERLINK] mentioned above. Fixed now.
Jason McCool 29.12.2020 16:22:00
