Beam calculation
Beam calculation - Ber7 - Messages
#1 Posted: 2011/11/19 16:24:17
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
https://smath.com/wiki/GetFile.aspx?File=Beam.rar
Oscar Campo 2011/11/19 23:33:00
#2 Posted: 2011/11/20 10:51:08
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Cantilever.rar
#3 Posted: 2011/11/20 10:51:45
Edward Ulle
Edward Ulle
21 likes in 182 posts.
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks.
Ed
#4 Posted: 2011/11/20 15:42:36
Fridel Selitsky
Fridel Selitsky
Ed
https://smath.com/wiki/GetFile.aspx?File=Cantileverzip.zip
https://smath.com/wiki/GetFile.aspx?File=Beamzip.zip
#5 Posted: 2011/11/20 16:41:50
Edward Ulle
Edward Ulle
Ber7,
Your animations and drawings always amaze me. Thanks.
Ed
#6 Posted: 2011/11/21 05:38:01
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Contin%5d.zip
#7 Posted: 2011/11/24 05:06:47
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=ElastFound.zip
#8 Posted: 2012/4/3 19:14:42
olik
olik
3 likes in 27 posts.
Hello.
This is very nice. I am civil ingenieer & I will use it. Thanks.
However it is dangerous to use the function x>Lf.
I found it out in my own beam programming.
When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down.
And for the following input it does not!
It seems to me, the function x>Lf does not work correctly each time.
Regards Olik
SMath files: beam 3 & 4.zip
Fridel Selitsky 2012/4/4 02:12:00, Andrey Ivashov 2012/4/4 02:05:00
#9 Posted: 2012/4/3 19:20:59
kmihaylovich
kmihaylovich
8 likes in 131 posts.
Olik, try to change x>Lf to eval(x>Lf).
Fridel Selitsky 2012/4/3 22:49:00, olik 2012/4/4 13:55:00
#10 Posted: 2012/4/3 22:52:33
Fridel Selitsky
Fridel Selitsky
Thank you, kmihaylovich, the file is corrected.
Regards,Ber7
#11 Posted: 2012/4/4 02:04:53
2,340 likes in 4,041 posts.
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
Regards.
#12 Posted: 2012/4/4 13:58:31
olik
olik
Thanks to all. The eval function seems to be a good way.
And if You fix this little bug, it will be the best.
Regards, Olik
#13 Posted: 2013/1/15 13:20:31
Fridel Selitsky
Fridel Selitsky
Single moving load
AnimBeam.smz (6.25 KiB) downloaded 1550 time(s).
Davide Carpi 2013/1/15 14:02:00, Oscar Campo 2013/1/15 15:29:00
#14 Posted: 2013/2/14 11:35:46
Fridel Selitsky
Fridel Selitsky
The load moves in deflection curve
AnimBeam1.smz (6.09 KiB) downloaded 1451 time(s).
Davide Carpi 2013/2/14 13:40:00
#15 Posted: 2013/3/20 18:20:44
Fridel Selitsky
Fridel Selitsky
Beam on elastic foundation.Movable load
MoveEl.smz (8.49 KiB) downloaded 1527 time(s).
Davide Carpi 2013/3/20 20:58:00
#16 Posted: 2013/6/11 05:10:10
Fridel Selitsky
Fridel Selitsky
Graphics with shading
(http://en.smath.info/forum/resource.ashx?a=1691)
AnimBeam2.sm (38.63 KiB) downloaded 1478 time(s).
4 users liked this post
Вячеслав Мезенцев 2013/6/11 12:00:00, ioan92 2013/6/11 05:58:00, IVR 2013/6/11 12:39:00, Davide Carpi 2013/6/12 19:18:00
#17 Posted: 2013/6/12 11:05:41
Fridel Selitsky
Fridel Selitsky
Cantilever-new edition
https://smath.com/wiki/GetFile.aspx?File=CantileverENExe.rar
CantileverEN.smz (18.82 KiB) downloaded 1555 time(s).
ioan92 2013/7/3 16:23:00, Davide Carpi 2013/6/12 19:19:00
#18 Posted: 2013/7/2 15:55:17
Fridel Selitsky
Fridel Selitsky
Beam with a variable distance between the supports
BemAnim.smz (15.6 KiB) downloaded 1455 time(s).
ioan92 2013/7/3 16:23:00, Andrey Ivashov 2013/7/3 17:19:00, Davide Carpi 2013/7/2 16:44:00
#19 Posted: 2013/7/6 14:29:47
Fridel Selitsky
Fridel Selitsky
Analysis of statically indeterminate beam. Supported cantilever.
Beam fixed at the one end supported an the other
https://smath.com/wiki/GetFile.aspx?File=Konsol%2bopora.rar
Konsol+opora.smz (134.15 KiB) downloaded 1541 time(s).
IVR 2013/7/7 14:46:00, Davide Carpi 2013/7/6 18:31:00
#20 Posted: 2021/2/11 03:32:36
Egidijus
Egidijus
0 likes in 2 posts.
Hello, could somebody help me. I don't understand how to solwe this problem.
