Vectors creation with ranged indices
Vectors creation with ranged indices - How to use vectors with subscripts (by typing: [) - Messages
#1 Posted: 2018/3/21 10:17:31
Rens
Rens
0 likes in 4 posts.
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround?
Best regards,
Rens Servais
File not found.File not found.File not found.
#2 Posted: 2018/3/21 10:54:39
1,443 likes in 2,935 posts.
Hello Rens,
You can do it in the same way, but indices here are base 1 instead of base 0
SMath file (r1).sm (4.53 KiB) downloaded 1029 time(s).
#3 Posted: 2018/3/22 07:12:23
Rens
Rens
0 likes in 4 posts.
Thanks a lot Davide!
Rens
#4 Posted: 2018/3/22 11:09:04
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2.93 KiB) downloaded 1014 time(s).
#5 Posted: 2018/3/22 11:20:17
What would be the expected result?
#6 Posted: 2018/3/22 11:26:42
Arie
Arie
94 likes in 285 posts.
You had Count as subscript instead of index in the loop.
Range2Vec program.smz (2.93 KiB) downloaded 1025 time(s).
#7 Posted: 2018/3/22 11:26:57
Ruben Sidranski
Ruben Sidranski
Wrong subscript ... Fixed Range2Vec.smz (3.31 KiB) downloaded 1059 time(s).
