Long Calculation Times
Long Calculation Times - The calculation does not end in some of my loops and can keep going for over an hour unless I end it - Messages
#1 Posted: 2020/7/10 19:23:57
huynha23
huynha23
0 likes in 1 posts.
I've tried CTRL+A and changing the optimization from symbolic to numeric on this sheet already, it did not help with my calculation run time. I'm hoping somebody can lead me in the right direction!
I've highlighted the loop that I'm trying to calculate.
I also tried running the sheet without any units and it took under a second to calculate. Is it normal for SMath to perform this way?
In-Class 2.6_1D conduction_SS and TS.sm (65.67 KiB) downloaded 1053 time(s).
#2 Posted: 2020/7/11 01:08:34
1,123 likes in 1,795 posts.
Hi. Check Delta_t.TS please.
#3 Posted: 2020/7/11 08:46:57
You can enrich the project from the very beginning.
Page24 Enrich Project.sm (23.59 KiB) downloaded 1166 time(s).
#4 Posted: 2020/7/12 09:42:45
The attached project was completed in collaboration.with the Originator.
Very closely related to yours. Superb model fit c/w its inverse/solve.
Inst_Thermal Insulation Copy.sm (127.36 KiB) downloaded 955 time(s).
#5 Posted: 2020/7/12 09:54:50
... the associated model fit.
Genfit Thermal Insulation.sm (49.24 KiB) downloaded 1002 time(s).
