1 Pages (5 items)
Least squares method - Least squares method with option to select the power of the polynomial - Messages
Another example of curve fitting by the least squares method
with option to select the power of the polynomial, or
select the adjustment of the curve to exponential or potential.
Ajust_by_Last_Square_Selection_Jean.sm (56.61 KiB) downloaded 1255 time(s).
Carlos
Carlos
5 users liked this post
frapuano 2019/4/26 04:12:00, sergio 2019/4/26 05:33:00, NDTM Amarasekera 2019/4/26 07:20:00, Arie 2019/4/26 09:38:00, Davide Carpi 2019/4/28 05:56:00
WroteAnother example of curve fitting by the least squares method
Hola Carlos !
Couldn't open the attached SS 7030 work sheet.
It happened another time from maybe Alvaro ?
Seemingly caused by 2 of your modules not activated.
My SS 6179 does not closed those two particular modules.
However, I have recognized the flat parabola data set.
I'm sure your proposal will have more applications.
Data sets with flat region best fit by model function,
like this one from al_nleqsolve, always assumed noisy.
Two flat parabolas attached
Thanks... Cheers ... Jean
Genfit [Algo Minimize(Cholesky_3 NonLinear)].sm (37.14 KiB) downloaded 992 time(s).
Genfit al_ nleqsolve [Edu Model FLAT Parabola].sm (30.24 KiB) downloaded 979 time(s).
Hola Carlos !
Hola Jean
Here you have a version in 6179 of the work sheet
of the method of adjustment of curves by least squares
Ajust_by_Last_Square_Selection_Jean_V6179.sm (52.77 KiB) downloaded 1275 time(s).
Cheers
Carlos
Hola Carlos.
Thanks for your contribution, most appreciated. More bed time reading.
VISITORS: download all, as they are minimalist Fit Classroom.
One more method is not listed wrt Polynomial fit: the Robert lsq.
Problem is that I can't make it work Mathcad ORIGIN (1)
Next Classroom is large as applied to a large collection of applied projects.
This next Classroom is mostly based on fitting parametric model function(s)
Genfit 0 Ge SubCryogenic.sm (38.93 KiB) downloaded 1081 time(s).
Genfit 00 Carlos-Cholesky.sm (37.2 KiB) downloaded 1133 time(s).
Genfit 0000 Adjust Linear.sm (49.98 KiB) downloaded 1141 time(s).
Genfit 000000 LinfitCheby.sm (77.69 KiB) downloaded 1132 time(s).
Genfit 00000 Linfit Linear.sm (32.52 KiB) downloaded 1146 time(s).
Genfit 000Carlos.sm (45.19 KiB) downloaded 1134 time(s).
Genfit 00000000 PolyOrder.sm (25.86 KiB) downloaded 1142 time(s).
Genfit 000000000 Thiele Corn Thermies.sm (44.32 KiB) downloaded 1162 time(s).
Genfit 0000000 Rational Auto-init ITER.sm (84.24 KiB) downloaded 1138 time(s).
Genfit 0000000000 Rational Num_Denom Order.sm (77.11 KiB) downloaded 1143 time(s).
... a must visit suite.
Three examples most useful for Engineering/Scientific
1. DE sol is intuitive of attempting a fit to your DE
2. Corn Thermies is more local agriculture
3. HadCRUt4 is most advanced Scientific.
So much BS & BK on that blabla parrot
BS & BK => from my old friend Ken [Bull Shit & Book Keeping].
Former Collab Theodore tried all possible orthogonal polynomials,
not to avail vs ChebyShev [I guess Russian does not lie]
Genfit 00000000000 LinfitCheby Order [DE sol].sm (30.19 KiB) downloaded 941 time(s).
Genfit 00000000000 LinfitCheby Order [Corn Thermies].sm (30.82 KiB) downloaded 963 time(s).
Genfit 00000000000 LinfitCheby Order [HadCRU].sm (193.77 KiB) downloaded 965 time(s).
1 Pages (5 items)
