solve & roots with units
solve & roots with units - Messages
#1 Posted: 2023/6/3 08:48:30
Valery Ochkov
Valery Ochkov
66 likes in 690 posts.
I can it solve in Mathcad - see please mcdx and pdf files
I try solve it (heat transfer) in SMath - see sm file
Help please
File not found.File not found.File not found.
#2 Posted: 2023/6/3 15:37:44
598 likes in 1,380 posts.
Help please
SMath symbolic solving of integration is not capable as Mathcad.
Thus integrals can't be used with numeric solvers.
However, you can use a little trick to solve them.
Using maple or maxima plugins is the key.
Here is your problem solved with various ways, roots() and Findroot().
solvewithunits.sm (23.4 KiB) downloaded 1233 time(s).
Valery Ochkov 2023/6/3 15:53:00, sergio 2023/6/4 13:03:00, NDTM Amarasekera 2023/6/4 03:15:00
#3 Posted: 2023/6/4 02:18:41
1,123 likes in 1,795 posts.
Hi. The attached have an al_nleqsol wrapper for a Mathcad block with units, that can accept SMath's integrals too.
Click to enlarge
Kerimov-Cvetkov-Velichko-1-7 - nSol.sm (17.97 KiB) downloaded 1275 time(s).
sergio 2023/6/4 13:03:00, Valery Ochkov 2023/6/4 02:22:00
#4 Posted: 2023/6/4 10:00:56
Actually, you don't need to find Tc2 first hand.
Findroot() can solve with all three equations at once.
All important is the order of unknowns.
Valery Ochkov 2023/6/4 12:03:00, sergio 2023/6/4 13:48:00
#5 Posted: 2023/6/5 00:08:21
Here is a paper-friendly version.
Also check how variable guess points are assigned.
Valery Ochkov 2023/6/5 02:23:00
#6 Posted: 2023/6/5 02:24:02
Valery Ochkov
Valery Ochkov
Thanks!
Send please the sm file.
#7 Posted: 2023/6/5 11:08:24
Hello Valery,
In some application(s), you can associate FindRoot with epsilon.
Solve Diophantine Chemical Balance epsilon.sm (106.1 KiB) downloaded 1301 time(s).
Valery Ochkov 2023/6/5 11:26:00
#8 Posted: 2023/6/5 17:39:04
Thanks!
solvewithunits.sm (14.13 KiB) downloaded 1226 time(s).
#9 Posted: 2023/6/26 02:33:01
netsonicyxf
netsonicyxf
2 likes in 79 posts.
Please help, why can't find root for this simple equation?
root.sm (20.2 KiB) downloaded 1203 time(s).
#10 Posted: 2023/6/26 05:54:06
1,443 likes in 2,935 posts.
Because there aren't unknows
#11 Posted: 2023/6/26 08:45:01
Please help,
why can't find root for this simple equation ?
roots solves wrt scalar function(s)
In this example, both functions are scalar wrt 'x'.
Try ... roots[(sin(x)-Gamma(x),x,1]
'x not defined' ... Gamma(x) is not scalar wrt 'x'
Few more numerical functions are not scalar
erf(x), erf(x,n) ... erfc(x), erfc(x,n) ...
#12 Posted: 2023/6/26 08:55:02
In that case and similar ones,
RootSecant algorithm will spits out 15 decimals, instantaneous.
#13 Posted: 2023/6/26 10:06:59
netsonicyxf
netsonicyxf
Thanks Davide.
Now I put "N" as unknown in the Eq. But it can't be solved either.
root.sm (19.41 KiB) downloaded 1188 time(s).
#14 Posted: 2023/6/26 10:58:58
You have to play a little with the precision, especially if there are units involved; in this case, seems that 10^-3 mm is a stable target (10^-2 works too, but in some case it returns the guess value, meaning that is "close enough" for the algorithm - you can see in the plot that 0kN to 200kN is in +0.02/-0.02mm range)
root_r1.sm (24.03 KiB) downloaded 1236 time(s).
netsonicyxf 2023/6/26 12:18:00
