1 Pages (4 items)
Bad Unit? - Long Ton v. Tonne v. Short Ton v. British Ton... - Messages
Greetings,
I just want to verify something quick: is 'tonne calibrated to the wrong value? If this is supposed to be a Long Ton, then I would've thought the value to be 2,240 lbm, but I'm seeing it as 2,204 lbm.
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
tonne in SMath it is defined as 10^3 kg that should be 2204,62 lbm
Wolfram: https://www.wolframalpha.com/input?i=1000+kg
Google: https://www.google.com/search?q=1000+kg+to+lbm
Edited 2025/6/6 08:34:20
Greetings,
You are correct; tonne is defined correctly. The "long ton (British ton)" is 2,240lbs; I was under the misunderstanding the British Ton and the Metric Tonne were the same unit of mass.
Better to always double check the units conversions .
There's also a short ton aka US ton; both short and long tons are defined as 1 ton =20 hundredweight, but the hundredweight is defined differently in US (100 pounds) and in Britain (112 pounds).
Edited 2025/6/7 10:28:14
⚜ Kenny Lemens, P.E. ᵂᴵ 2025/6/16 20:39:41
1 Pages (4 items)
