Bad Unit?
Bad Unit? - Long Ton v. Tonne v. Short Ton v. British Ton... - Сообщения
#1 Опубликовано: 05.06.2025 21:10:38
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 179 понравились пользователям.
Greetings,
I just want to verify something quick: is 'tonne calibrated to the wrong value? If this is supposed to be a Long Ton, then I would've thought the value to be 2,240 lbm, but I'm seeing it as 2,204 lbm.
May this be of Good Help;
#2 Опубликовано: 06.06.2025 08:33:10
tonne in SMath it is defined as 10^3 kg that should be 2204,62 lbm
Wolfram: https://www.wolframalpha.com/input?i=1000+kg
Google: https://www.google.com/search?q=1000+kg+to+lbm
Отредактировано 06.06.2025 08:34:20
Andrey Ivashov 06.06.2025 22:01:11, ⚜ Kenny Lemens, P.E. ᵂᴵ 06.06.2025 22:07:10
#3 Опубликовано: 06.06.2025 22:06:55
Greetings,
You are correct; tonne is defined correctly. The "long ton (British ton)" is 2,240lbs; I was under the misunderstanding the British Ton and the Metric Tonne were the same unit of mass.
#4 Опубликовано: 07.06.2025 10:27:55
Better to always double check the units conversions .
There's also a short ton aka US ton; both short and long tons are defined as 1 ton =20 hundredweight, but the hundredweight is defined differently in US (100 pounds) and in Britain (112 pounds).
Отредактировано 07.06.2025 10:28:14
⚜ Kenny Lemens, P.E. ᵂᴵ 16.06.2025 20:39:41
