Fit Methods Essentials
Fit Methods Essentials - Fit Methods Essentials - Messages
#1 Posted: 2020/1/27 18:30:51
Global fitting session [0 .. 14]
1. al_nleqsolve point select equalities
valid for noisy data via user piecewise linear.
2. Levenberg-Marquardt: generally valid [fails Frechet]
3. Cholesky matrix solver ... solves all, faster
model function(s) parameters, linfit components,
remarkable linfitCheby, polyorder, direct discrete data.
............................ rational fraction.
EMERITUS => Conjugate gradient Minimize(init,iter)
Genfit_0 Read First.sm (32.45 KiB) downloaded 1146 time(s).
Genfit_2 L-M AUTOMATED PieceWise-Global Reflexive Copy.sm (69.25 KiB) downloaded 1185 time(s).
Genfit_4 linfit HyperRobust [Ge Crystal] Copy.sm (82.26 KiB) downloaded 975 time(s).
Genfit_7 GenfitMatrix Copy Master ToolBox Copy.sm (62.69 KiB) downloaded 1192 time(s).
Genfit_9 Chemist.sm (34.68 KiB) downloaded 1122 time(s).
Genfit_5 LinfitCheby Order [HadCRU] Copy.sm (120.98 KiB) downloaded 985 time(s).
Genfit_8 Poly 000 Order System.sm (20.15 KiB) downloaded 1133 time(s).
Genfit_3 L-M AUTOMATED PieceWise Carlos Original Copy.sm (130.72 KiB) downloaded 1169 time(s).
Genfit_6 Rational Auto-init ITER [LongRange type_J] Copy.sm (123.72 KiB) downloaded 934 time(s).
Genfit_11 Pharmacokinetics LMSA ... [Carlos 2020].sm (50.36 KiB) downloaded 994 time(s).
Genfit_10 Frechet.sm (96.8 KiB) downloaded 1153 time(s).
Genfit_13 NON-Linear.sm (37.25 KiB) downloaded 1191 time(s).
Genfit_1 L-M AUTOMATED Carlos 20200115 [Exampless] Copy.sm (265.69 KiB) downloaded 942 time(s).
Genfit_14 AUTOMATED al_nleqsolve.sm (83.36 KiB) downloaded 1164 time(s).
Genfit_12 Pharmacokinetics LM ... [Carlos 2018].sm (55.45 KiB) downloaded 964 time(s).
NDTM Amarasekera 2020/1/28 04:28:00
#2 Posted: 2020/1/28 11:34:28
1 ... please: recycle Genfit_14
replace by high pro refreshed/augmented.
2. Add Genfit_15 [Thiele Procedure]
Genfit_15 Thiele Procedure [Carlos-Jean].sm (76.66 KiB) downloaded 984 time(s).
Genfit_14 AUTOMATED al_nleqsolve.sm (85.48 KiB) downloaded 1191 time(s).
#3 Posted: 2020/1/30 13:27:00
... add this Meritas to your tool box.
Genfit_16 MERITAS al_nleqsolve.sm (29.95 KiB) downloaded 1156 time(s).
#4 Posted: 2020/1/30 13:44:43
CBG
CBG
78 likes in 312 posts.
Hola Jean
This is my best setting for "Genfit_10 Frenchet" in SS-6179
with LM using 6 data, since an out of memory error occurs using all data.
SS-7251 solves it without any problem with all the data.
Genfit_10 Frenchet LMSA ..SS6179.sm (56 KiB) downloaded 1127 time(s).
Genfit_10 Frenchet LMSA ..SS7251.sm (45.17 KiB) downloaded 1144 time(s).
Carlos
#5 Posted: 2020/1/30 14:45:05
CBG
CBG
Hola Jean
Genfit_16 MERITAS resolved with LMSA in SS-6179 and SS-7251.
Genfit_16 MERITAS LMSA_SS6179.sm (53.02 KiB) downloaded 1155 time(s).
Genfit_16 MERITAS LMSA_SS7251.sm (52.9 KiB) downloaded 1183 time(s).
Carlos
#6 Posted: 2020/1/31 07:54:58
Hola Jean
This is my best setting for "Genfit_10 Frechet" in SS-6179
Thanks Carlos, got 9 points superb fit !
Next will check MERITAS ...
Genfit_10 Frenchet LMSA ..SS6179.sm (55.67 KiB) downloaded 1158 time(s).
#7 Posted: 2020/1/31 11:35:11
Hola Jean
Thanks Grand Doctor Carlos ...
So, my native SS 6179 suffers numerical issue
that SS 7251 cures in your SS 6179 ... Ah !
LMSA in native SS 6179 takes much higher TOL [typical 0.0001/0.00001]
F.B. Hildebrand wrote "fitting is an art ..."
Can't be more right !
