Fit Methods Essentials
Fit Methods Essentials - Fit Methods Essentials - Сообщения
#1 Опубликовано: 27.01.2020 18:30:51
Global fitting session [0 .. 14]
1. al_nleqsolve point select equalities
valid for noisy data via user piecewise linear.
2. Levenberg-Marquardt: generally valid [fails Frechet]
3. Cholesky matrix solver ... solves all, faster
model function(s) parameters, linfit components,
remarkable linfitCheby, polyorder, direct discrete data.
............................ rational fraction.
EMERITUS => Conjugate gradient Minimize(init,iter)
Genfit_0 Read First.sm (32,45 КиБ) скачан 1306 раз(а).
Genfit_2 L-M AUTOMATED PieceWise-Global Reflexive Copy.sm (69,25 КиБ) скачан 1349 раз(а).
Genfit_4 linfit HyperRobust [Ge Crystal] Copy.sm (82,26 КиБ) скачан 1125 раз(а).
Genfit_7 GenfitMatrix Copy Master ToolBox Copy.sm (62,69 КиБ) скачан 1337 раз(а).
Genfit_9 Chemist.sm (34,68 КиБ) скачан 1272 раз(а).
Genfit_5 LinfitCheby Order [HadCRU] Copy.sm (120,98 КиБ) скачан 1133 раз(а).
Genfit_8 Poly 000 Order System.sm (20,15 КиБ) скачан 1283 раз(а).
Genfit_3 L-M AUTOMATED PieceWise Carlos Original Copy.sm (130,72 КиБ) скачан 1325 раз(а).
Genfit_6 Rational Auto-init ITER [LongRange type_J] Copy.sm (123,72 КиБ) скачан 1083 раз(а).
Genfit_11 Pharmacokinetics LMSA ... [Carlos 2020].sm (50,36 КиБ) скачан 1133 раз(а).
Genfit_10 Frechet.sm (96,8 КиБ) скачан 1303 раз(а).
Genfit_13 NON-Linear.sm (37,25 КиБ) скачан 1336 раз(а).
Genfit_1 L-M AUTOMATED Carlos 20200115 [Exampless] Copy.sm (265,69 КиБ) скачан 1098 раз(а).
Genfit_14 AUTOMATED al_nleqsolve.sm (83,36 КиБ) скачан 1330 раз(а).
Genfit_12 Pharmacokinetics LM ... [Carlos 2018].sm (55,45 КиБ) скачан 1104 раз(а).
NDTM Amarasekera 28.01.2020 04:28:00
#2 Опубликовано: 28.01.2020 11:34:28
1 ... please: recycle Genfit_14
replace by high pro refreshed/augmented.
2. Add Genfit_15 [Thiele Procedure]
Genfit_15 Thiele Procedure [Carlos-Jean].sm (76,66 КиБ) скачан 1131 раз(а).
Genfit_14 AUTOMATED al_nleqsolve.sm (85,48 КиБ) скачан 1349 раз(а).
#3 Опубликовано: 30.01.2020 13:27:00
... add this Meritas to your tool box.
Genfit_16 MERITAS al_nleqsolve.sm (29,95 КиБ) скачан 1310 раз(а).
#4 Опубликовано: 30.01.2020 13:44:43
CBG
CBG
Hola Jean
This is my best setting for "Genfit_10 Frenchet" in SS-6179
with LM using 6 data, since an out of memory error occurs using all data.
SS-7251 solves it without any problem with all the data.
Genfit_10 Frenchet LMSA ..SS6179.sm (56 КиБ) скачан 1285 раз(а).
Genfit_10 Frenchet LMSA ..SS7251.sm (45,17 КиБ) скачан 1287 раз(а).
Carlos
#5 Опубликовано: 30.01.2020 14:45:05
CBG
CBG
Hola Jean
Genfit_16 MERITAS resolved with LMSA in SS-6179 and SS-7251.
Genfit_16 MERITAS LMSA_SS6179.sm (53,02 КиБ) скачан 1322 раз(а).
Genfit_16 MERITAS LMSA_SS7251.sm (52,9 КиБ) скачан 1341 раз(а).
Carlos
#6 Опубликовано: 31.01.2020 07:54:58
Hola Jean
This is my best setting for "Genfit_10 Frechet" in SS-6179
Thanks Carlos, got 9 points superb fit !
Next will check MERITAS ...
Genfit_10 Frenchet LMSA ..SS6179.sm (55,67 КиБ) скачан 1307 раз(а).
#7 Опубликовано: 31.01.2020 11:35:11
Hola Jean
Thanks Grand Doctor Carlos ...
So, my native SS 6179 suffers numerical issue
that SS 7251 cures in your SS 6179 ... Ah !
LMSA in native SS 6179 takes much higher TOL [typical 0.0001/0.00001]
F.B. Hildebrand wrote "fitting is an art ..."
Can't be more right !
