SMath units
SMath units - Wrong units - Messages
#1 Posted: 2023/11/24 05:13:51
Oichi
Oichi
4 likes in 35 posts.
For a simple harmonic oscillator with mass "m" (kg) and spring constant "k" (N/m), the angular frequency of oscillation is sqrt(k/m).
If we used the SI units, the angular frequency unit should be (rad/s) but when I use units in SMath it gives the answer in Hz..
So, is there a way that I can correct the units for an answer? Thanks in advance
#2 Posted: 2023/11/24 17:38:44
Oscar Campo
Oscar Campo
135 likes in 309 posts.
You can change units in this way...
Oscar
Oichi 2023/11/25 00:36:00
#3 Posted: 2023/11/25 00:13:01
... Unit User Hz ... rad_s.sm (2.82 KiB) downloaded 1222 time(s).
Oichi 2023/11/25 00:40:00
#4 Posted: 2023/11/25 00:40:02
Oichi
Oichi
Thank you all ^^
Oscar Campo 2023/11/25 03:57:00
