Multiple Binary Boolean Operators in if statement
Multiple Binary Boolean Operators in if statement - Add multiple binary Boolean "or" / "and" operators without force parenthesis - Messages
#1 Posted: 2022/5/6 22:53:10
Larry Burns
Larry Burns
0 likes in 3 posts.
When I try to perform this if-or statement:
if a=1 ^ a=2 ^ a=3
x=4
else x =5
I end up with this due to forced parenthesis:
if ((a=1 ^ a=2) ^ a=3)
x=4
else x =5
Could we have capability for multiple binary operators without forced parenthesis enclosure?
#2 Posted: 2022/5/7 00:27:03
1,123 likes in 1,795 posts.
Hi. The short and honest answer is not. The long and tricky answer is that you can, but you must edit the .sm file and delete the lines with (
However, unless it's for some publishing purpose or something like that, I don't think it's convenient. Also, you can neither copy nor edit it without the parentheses reappearing.
and_tryck.sm (2.75 KiB) downloaded 1392 time(s).
#3 Posted: 2022/5/7 08:59:32
Think in term of productive Bolean.
Critical.sm (30.49 KiB) downloaded 1415 time(s).
#4 Posted: 2022/5/9 08:01:56
... lot more involved. Adapted from Frank Rioux MCD 11.
Fourier Quantum 2C Mask.sm (22.51 KiB) downloaded 1435 time(s).
#5 Posted: 2022/5/9 08:37:41
1,443 likes in 2,935 posts.
You can always create some function to make it look like you are working with some set of numbers
sergio 2022/5/9 10:55:00, Alvaro 2022/5/9 11:19:00, Arie 2022/5/9 16:16:00
#6 Posted: 2022/5/9 10:06:38
Tanks Davide ... coded/saved.
Take care ... Jean.
Maths Conditional Davide.sm (12.36 KiB) downloaded 1426 time(s).
sergio 2022/5/9 12:46:00
#7 Posted: 2022/5/9 11:25:27
Hi Davide. Great idea. These functions can be very useful for translating matlab programs. They can also be extended to arrays, as the all, any and nnz functions do.
