Rendering matrix columns
Rendering matrix columns - Last column of 6x6 matrix does not show. - Messages
#1 Posted: 2018/2/24 14:08:08
Peter Richards
Peter Richards
0 likes in 2 posts.
I am showing the content of a numerical 6x6 matrix but the last column is not displayed, I can index into the last column so it is clearly just the rendering. Does anyone know of a way to get the 6th column to show?
#2 Posted: 2018/2/24 15:16:47
Something wrong ... definitly/definitively
Please, attach the document, it may need be doctored.
Utilities Matrix Delta.sm (40.61 KiB) downloaded 605 time(s).
#3 Posted: 2018/2/24 15:31:06
1,435 likes in 2,913 posts.
The content might be hidden if the matrix is too large (number of elements or width/height)
Check if there are ellipsis displayed on the left/bottom edges and drag them aroud to display the hidden content.
Otherwise as suggested above attach the file that doesn't work for you
frapuano 2018/2/24 17:46:00
#4 Posted: 2018/3/3 09:26:37
Peter Richards
Peter Richards
0 likes in 2 posts.
Thanks for replies - it does show an ellipsis and dragging has uncovered the hidden column. Problem solved!
#5 Posted: 2018/3/3 11:18:45
Problem solved <= Answer Problem NOT solved
The "ellipsis" feature [Smath 6179 ...] is convenient to display limited check from long
vector(s)/matrix ... however: can't be used to collect the entire result [it collect
what is displayed only]. To collect the entire result ... like this:
1. result
2. [result] from matrix drop down menu 1 row by 1 col
3. [result]= set decimal places, F9 to calculate
4. @ this point, you can export the entire vector/matrix.
