How to change the value
How to change the value - Messages
#1 Posted: 2014/6/8 10:42:08
justinas
justinas
0 likes in 1 posts.
I just started to use Smath today, and I can not believe how comfortable and good this program is (keeping in mind it is for free).
I actually going to use it for engineering, so I need to describe all the values in the equations.
For example
M:= F*m
F:= 6Newtons
m:= 2meters
The answer I want to get is M=12Nm
The answer I get is M=12J.
How do I change the answer to Nm?
#2 Posted: 2014/6/8 11:24:47
1,443 likes in 2,935 posts.
Hello justinas, welcomw to us
The output unit is always a SI base unit. To have your desired unit go to the empty placeholder on the right and type what you need ('N*'m in your example)
best regards,
Davide
#3 Posted: 2014/7/7 08:06:36
kadpeter
kadpeter
0 likes in 10 posts.
there aren't moment and torque units in SMath (which is "Nm" in SI), therefore I define "Nm" in the invisible area:
'Nm:='N*'m
After that you can use "Nm" too.
Best regard
Peter
