How to change the value
How to change the value - Сообщения
#1 Опубликовано: 08.06.2014 10:42:08
justinas
justinas
I just started to use Smath today, and I can not believe how comfortable and good this program is (keeping in mind it is for free).
I actually going to use it for engineering, so I need to describe all the values in the equations.
For example
M:= F*m
F:= 6Newtons
m:= 2meters
The answer I want to get is M=12Nm
The answer I get is M=12J.
How do I change the answer to Nm?
#2 Опубликовано: 08.06.2014 11:24:47
1 441 сообщений из 2 932 понравились пользователям.
Hello justinas, welcomw to us
The output unit is always a SI base unit. To have your desired unit go to the empty placeholder on the right and type what you need ('N*'m in your example)
best regards,
Davide
#3 Опубликовано: 07.07.2014 08:06:36
kadpeter
kadpeter
0 сообщений из 10 понравились пользователям.
there aren't moment and torque units in SMath (which is "Nm" in SI), therefore I define "Nm" in the invisible area:
'Nm:='N*'m
After that you can use "Nm" too.
Best regard
Peter
